How about not using VB? I'm sorry, that was uncalled for. I normally have enlightening unbiased replys. Not this time though. VB sucks, learn a real programming language.![]()
hello, i have a question. Does anyone have a small example of how to build a control in vb.net 2005? i have found examples in vb.net 2003 on google, but not anything special for 2005.
What i want to build is a control that will give me some values. for example: lets say i use a control called "mycontrol" So when i take mycontrol.value1 it will return 5 , when i want mycontrol.value2 it will return 232 and so on.
Is this possible? I know it looks more like a function than a control but i wanna use it as a control. Please let me know. thanks
-VIA EPIA M10000/512MB/40GB HD
-DWW motorized 7'
-BU 303 GPS w/iGuidance/ CF
-Opus90w
-Belkin Bluetooth
-Pioneer HU
[||||||||||] 95% done
thanx for your comments but i need to do it on vb.net 2005. i have done the whole project in that and i am not planning to learn another language cause vb sucks. i have a little time to work on my hobbie stuff and vb is covering good enough.
-DWW motorized 7'
-Opus90w
-Belkin Bluetooth
-Pioneer HU
i work with vb.net 2003 is there any difference in coding ?
not sure, but when i found some examples online, vb2003 has a selection at the beginning where you can make a new control /library, but vbnet2005 does not. so i started it as a class but it did not work..
-DWW motorized 7'
-Opus90w
-Belkin Bluetooth
-Pioneer HU
2003 and 2005 framework libraries are relatively the same, there really shouldn't be any difference in the code, with the exception that the templates use partial classes.
Have a look at the Microsoft website under visual studio 2005. There are a lot of tutorials to be found if you take the time to look. I've been using visual studio 2005 beta 2 to do some web development, and most of the work now is just drag and drop. How are you .Net skills?
thanx people, i have been having some progress with that, i think i am getting there! yeah i checked the msdn website. there is lots of info there!
-DWW motorized 7'
-Opus90w
-Belkin Bluetooth
-Pioneer HU
Why a control and not a class? If you ABSOLUTELY need these values on a control then just create a property in the control.
Code:Public Property TheProperty(tst as integer) as integer Get Return value Set (tst as integer) value = tst end Property
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
Originally Posted by TheLlama
Oh yea, VB is a real programming language if you don't use it then don't comment on it. In the past VB was a "hobbiest language" now its very powerful. I'm so sick of poeple being stuck in thier safe little C/C++ bubbles, thinking no programming language can beat it. Here's a word of advice: .Net 2005 changes that my friend so jump on the bus or be one of the few left behind.... Learn to like vb or c# (afterall they created C# for you guys in the bubble to be able to easily migrate over to a VB like, managed, language)
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
