i believe that if you dim your variable using global instead, it's available to your whole project. ex:
etc.Code:global myVariable as Integer
Hope this helps
Sorry for asking but.......
<edit> found what I need.
<edit> Now have another issue.......
Global integers in VB5, HOW?! <edit>thanks! kamikaze2112!
Next problem
In days of old when code was bold I would..........
Open "settings.ini" for input as #1
<edit> Done found some nice litle routine for ini file reading/writing
<edit> Well here I am still at the machine 10 hrs later! Can now read/write mouse position and red jostick and use joystick to move mouse etc
And problem 65536: How to find the current volume level!<edit> And I have found it! a further 4 hours on google and lots of 'classes' and 'modules' some small some bloody huge I have a medium sized one with a setvol/getvol! 14hrs! thought it would take at least a day to find....
Sorry for being clueless but the damn language hates me, the help files are useless and the 'guides' are padded with dumbing down to the point of being useless, bring back old basic!
Hope this helps
Thanks, I really mean thanks, I bet 100ppl who visit this group new that etc.Originally Posted by kamikaze2112
I did find it, its a little hard to learn the sytax of a language your not used to when you dont have the manuals/books etc.
google is useless for most of this, I spent hours yesterday trying to find out how to control the volume, and I still can only set it I cant find how to read the current value so I can restore it on program exit.
Although I think wmm.dll plays a part.
Lots of examples on the VB sites dont load in, the complain of unsupported keyewords etc, most common one is 'retained=0'
I dont know what it is, but if you text edit the file, remove that re-save and reload its fine, so maybe its a reference for other versions not supported in v5 that i'm using.
SO my adventure continues, and today I will spend many more hours on goole and vb sites trying to find the elusive read volume command. (audio not drive name)
Lez, more widely known as flez1966
depending on the version of media player you are using, i believe the volume stuff is
You really could use to download the SDK for whatever version of media player you are coding for. Alot of people say that WMP9 is the way to go, but I like 10 myself. It will help you out with all the methods, constants, events, properties, etcCode:windowsmedia1.settings.volume = {integer between 0 and 100}
No I want to 'variable=master.volume' not 'master.volume=variable'
I had found lots of ''classes' and 'modules' that had a setvol type command but dont come with a getvol.
But by about 10pm I had found one and I stopped at midnight for a break, from 8am, but I have it, working!
Thanks for your reply.
