Results 1 to 10 of 10
Thread: VS2005 + image rendering optimization...
    Newbie Aldaris's Avatar
    Nov 2005
    Trois-Rivières, QC
    Hi guys!
    I am developping my own media center software in C# with Visual Studio 2005. It is going well, I programmed all the engine to generate my forms dynamically from an xml file(the skin), but now that it works, the problems I was suspecting from the beginning happened!
    When the form loads and shows up on the screen, every control arrives one after the other, kinda slow... And it is the same thing on each OnPaint of the form...
    I am using Image.FromFile(filename); to preload my images and when I create my form, I create the controls from the list of controls I got from the xml file. I don't think the problem comes from here since it is loaded before the OnPaint, and alse because the problem happens on every OnPaint after the form is created...
    So my question is : Does anybody have encountered this problem, and is there a way to make the controls refresh faster!!??
    Thank you!
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Maybe you have some repeated call to invalidate your form while you're painting the controls.
    You should do a Debug.WriteLine each time you're in OnPaint to find that out.
    Loading the image from file is ok if you don't do that in OnPaint. Another thing to mention is the image size. If it's resized during the painting it may cost valueable time.
    Maybe you could post a snippet of your OnPaint routine.
    Skinning to go... VisualDesigner2!
    Nov 2005
    Trois-Rivières, QC
    In fact, I don't have any code in my OnPaint method for now... it's all done automatically by the base class (System.Windows.Forms).
    Today, I tried to remove the background image to check it this could be the problem, and the result is positive! As soon as I removed the background image, the others controls, begans to refresh normally!
    So now my question is, is there a special way to control the refresh of the background image to make it faster?
    Since the image is 800x600 and 414ko, I will try to drop the quality of the image to get a smaller size when I get the time... we'll see if it does something!
    Nov 2005
    Trois-Rivières, QC
    nop, no effect at all!
    Sep 2003
    Finland
    Hi!
    I've had same problem, and I just tested below and it seems much faster.
    protected override void OnPaintBackground(PaintEventArgs e)
    // if backgroundimage is set, use it
    if (BackgroundImage != null)
    e.Graphics.DrawImage(BackgroundImage, e.ClipRectangle, e.ClipRectangle, GraphicsUnit.Pixel);
    else
    // else paint with backcolor
    using (SolidBrush brush = new SolidBrush(BackColor))
    e.Graphics.FillRectangle(brush, e.ClipRectangle);
    Looks like that originally forms background paint isn't very efficient...
    But this only works when backgroundimage isn't scaled.
    vvog
    Maximum Bitrate DeltaFX's Avatar
    France
    Can't you set your form as Doublebuffered ? Basically it repaints in background then swap display.
    Now Galileo is real. Muhahahahaha :p
    Nov 2005
    Trois-Rivières, QC
    My form is already set as DoubleBuffered, but it didn't changed anything...
    And thank you vvog for the code, I tried it very fast, but I didn't see any difference, I'll try to test it more when I get some time. Do you override only the onpaint of the form, or the others images on top of that too?
    Thanx
    The Car : Nissan Sentra SE-R Spec V 2003
    The CarPC : Via M10k - 256mb - sb Live 5.1 - lilliput 7''
    Media Center status : 33%
    Car Installation status : 33%
    WorkLog : http://mp3car.com/vbulletin/showthread.php?t=77258
    Nov 2005
    Trois-Rivières, QC
    This time I took the time to test it, and it is very positive!
    We can still see the images refresh, but it's a lot faster than before, and it's very acceptable!
    Thanx alot for your help vvog, I was stocked on this bug for a while!
    See you around!
    Sep 2005
    using GDI it will be very slow... why not try using DirectX? its quite simple to use and increases rendering performance many times over!
    Feb 2006
    you could try...
    Code:
    Public Declare Function LockWindowUpdate Lib "user32" (ByVal Handle As Long) As Long
    LockWindowUpdate(Me.Handle.ToInt64)
    //do painting
    LockWindowUpdate(0&)
  1. [REVIEW] In-Bumper Rear-view camera
    By RoyN in forum General Hardware Discussion
    Last Post: 12-30-2006, 02:42 PM
  2. Help w/ backup, restore, or image drive/disk for recovery
    By ITL in forum Software & Software Development
    Last Post: 10-25-2005, 08:33 AM
  3. Replies: 10
    Last Post: 07-28-2005, 02:29 PM
  4. Lilliput no image
    By linzhang in forum LCD/Display
    Last Post: 11-02-2004, 08:02 AM
  5. DWW-7VGA won't display image
    By guf in forum LCD/Display
    Last Post: 05-08-2004, 05:06 PM
