What language is this ?
is to make a small adjustment driver of tuch panel.
the tecnic department of EGALAX
they do not understand to me
because I want to change the world
or they do not want to recognize its failures
one is the following thing.
beginning to driver tuch now panel: white screen 4 points fits,
if point is not touched ningun they,en 1 minute loads driver automatical
modification: black screen time maxim to fit to 4 points 1 second
result: automatic load of driver in xp with previous adjustment
advantages: it does not bother at sight mouse and tuch without problems
my knowledge do not give for that modification if somebody sees it feasible I animate I believe that it can be of utility to many
Now Galileo is real. Muhahahahaha :p
Me no understood!
We are, will have and forever will be...
But not tommorrow!
SOY ESPAÑOL Y NO ESCRIBO INGLES POR ESO RECURRO A LA TRADUCCION AUTOMATICA PERO PARECE QUE NO ME FUNCIONA BIEN
pero si alguien sabe español aqui va mi exposicion
alguien sabria hacer que la utilidad de ajuste de 4 puntos que se inicia al principio de win con los drivers de tuch panel hiciera esto
iniciar con fondo negro pero con una duracion de SOLO 1 segundo
asi se cargan automaticamente el driver del tuch casi sin tocar nada
Now i get it!![]()
But not tommorrow!
Hey ramalo si estas hablando de los drivers para touchscreen dejame decirte que algo anda mal con los que tienes, yo lo uso a diario y nunca hace esto.Originally Posted by ramaloji
Por otro lado yo creo que tu TS utility esta en la carpeta de startup, entonces ocurre esto (analiza si ese es el caso, y borralos)
Espero que sea de ayuda.
Thanatos.
DAMN, this site gives support in Spanish. Dats tight.Originally Posted by thanatos106
It actually brought a tear to my eye that we are ALL so helpful.
Michael
Thanatos.
Although, for all I know, you could have cursed him out and told him to leave.Originally Posted by thanatos106
Michael
