yes, or double-click it.
Really? So i can just put that in the startup folder and it will work?
Awesome, then is that the right code? it did have a wait command, then a turn off serial port at the end but it just deleted it because i want it to stay on until the program is stopped on shutdown... do i need to put a loop command in? or will that keep the signal going until shutdown?
not sure how that COM object you're using works...you may need to put a wait or sleep command at the end to keep the script running... http://msdn.microsoft.com/library/en-us/default.aspenjoy!
Mmm Mmm good. nothing like VB scripts being run by a privileged user.
