Results 1 to 10 of 10
Thread: vb6 Help generating a random number
    FLAC J187's Avatar
    Nov 2004
    Boston
    I want to load a label with a random selection from a listbox with 22 items in the list. Currently I am using
    intRand = Int(Rnd * 22)
    List1.ListIndex = intRand
    List1.Selected(intRand) = True
    Label1 = List1
    the problem is, VB's RND function returns the same exact random number sequence every time the program is run - that's not very Random, is it?
    5.33424
    5.795186
    2.895625
    etc
    etc
    Anyone help me get a real Random selection??
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Nov 2005
    Just write Randomize before rnd. That will solve the problem.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Ok, if I use
    intRand = Int(randomize(Rnd * 22))
    Label1 = List1
    which is what I think you are saying..
    I get an error - Expected expression or variable for Randomize.
    Now if do this,
    Dim intRand As Integer
    Dim strnewword As String
    Dim intBoxIndex As Integer
    Randomize (intRand)
    Label1 = List1
    I get a different order the words come in, but its still the same exact order everytime I load my project. Is there still something I'm doing wrong, thanks for you help..
    Please help.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Seed the random number generator using a non deterministic source. Eg, system time.
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by Rob Withey
    Haha, I thought of doing that, then I thought "that's Crazy". Guess not, thanks.
    Please help.
    FLAC J187's Avatar
    Nov 2004
    Boston
    actually what I decided to do was use a timer with a 50 millisecond interval to keep things random.
    intRand = Int(Rnd * mintTimer)
    Label1 = List1
    Private Sub Timer1_Timer()
    'Generate random multiplier w/ timer
    If mintTimer < 20 Then
    mintTimer = mintTimer + 1
    Else
    mintTimer = 0
    End If
    End Sub
    Thank you guys very much!
    Please help.
    Aug 2004
    Australia
    Nah dude with the randomize he means in you code write it like this:
    Randomize
    Label1 = List1
    Raw Wave
    Jun 2004
    On the beach
    I was about to recommend that as well
    Mar 2006
    i believe randomize starts the sequence somewhere new based on the system clock's miliseconds or something like that. so it isnt truely random, but the number of numbers in the sequence is in like the trillians or something
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    sorry to revive a dead thread but I have some insight to the problem to experience.
    When you call the Rnd functions it keeps in memory the value that was used to generate the random number. Calling Rnd again will give you the same number. Calling Randomize resets the stored value for generating the random number just like Eubey has suggested.
    If you take a look at C or C# as an example, to randomize a number in these enviroments you need to specify a seed and most programmers use the System Time to generate it. Since VB is just simplified and no built in seed method exists the Randomize functions is the way to reset the seed.
  1. Remove song number in database?
    By tmar89 in forum Media Engine
    Last Post: 02-25-2005, 02:45 PM
  2. Random...Little too Random
    By Prindle19 in forum Centrafuse
    Last Post: 01-17-2005, 06:30 PM
  3. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  4. Error #91
    By SiGmA_X in forum ME Archive
    Last Post: 01-08-2004, 10:40 PM
  5. MPXPlay / MPXF ... random play
    By DaBretty in forum Software & Software Development
    Last Post: 07-20-2000, 10:32 PM
