Results 1 to 2 of 2
Thread: GPS help please
    Constant Bitrate ThEScReW's Avatar
    Nov 2004
    GPS help please
    Hi, i have this file :
    And with that source of reading out the gps (written in VB6) I would like to measure the acceleration of the car, the usage of fuel ( by entering minimum, maximum and averige usage before first use) Range of kilometers left with the fuel, .....
    You know, but the problem i have, vb is a long time ago for me and i don't know why i cannot make a good program.
    Normally the program here will work, but the real good functions are not added yet.
    When i ad them, i have a problem, it tells me that the MSCOMM port gives an error .....
    Can a coder help me or code it for me
    Thank you
    Mar 2005
    for to find which is the error, you can try to use the code:
    In Oncom event.
    Private Sub MSComm1_OnComm()
    On Error Resume Next
    Select Case MSComm1.CommEvent
    ' Error
    Case comEventBreak ' Ricevuto un segnale di interruzione.
    Case comEventFrame ' Errore di frame.
    Case comEventOverrun ' Perdita di dati.
    Case comEventRxOver ' Overflow buffer di ricezione.
    Case comEventRxParity ' Errore di paritÓ.
    Case comEventTxFull ' Buffer di trasmissione pieno.
    Case comEventDCB ' Errore imprevisto durante il recupero di DCB.
    ' Events
    Case comEvCD ' Modifica della linea CD.
    Case comEvCTS ' Modifica della linea CTS.
    Case comEvDSR ' Modifica della linea DSR.
    Case comEvRing ' Modifica dell'indicatore del segnale telefonico.
    Case comEvReceive ' Ricevuto il numero di caratteri RThreshold.
    Case comEvSend ' Il buffer di trasmissione include il numero di caratteri specificato da SThreshold.
    Case comEvEOF ' ╚ stato trovato un carattere EOF nel flusso di input.
    End Select
    end sub
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  2. Cell Phone GPS
    By EBFoxbat in forum GPS
    Last Post: 09-14-2005, 07:45 AM
  3. Replies: 8
    Last Post: 03-26-2005, 11:29 AM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
  5. Replies: 9
    Last Post: 10-25-2004, 02:34 AM
