Results 1 to 7 of 7
Thread: XM Direct Protocol ?
    Feb 2006
    Dallas
    First, I have searched, but I cannot find a source that describes how the commands are sent and data is received from the XM Direct device. I have one and it works with Road Runner, but I would like to find an uptodate listing of how the communications work so that I could do some programming. I looked at the Road runner source, but there is a tremendous amount of code in that app. My hat is off to anyone who can manage all of that.
    Anyone have a writeup, or some VB code that only covers this area?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    It's a series of bits that you send to the serial port.
    For example, "5A, A5, 00, 05, 00, 10, 10, 01, ED, ED " will power the unit up.
    I did a Google on "XM Direct Protocol" and got the following link: http://weblogs.asp.net/bstahlhood/ar...06/347438.aspx
    Want to:
    Feb 2006
    Dallas
    Thanks for the info Bugbyte, but I'm pretty sure that I have been there before and the link to the document is still dead.
    BTW I have spent a lot of time searching thru a lot of subjects since I signed up a couple of weeks ago, but because there is so much, it get very fustrating at times.
    Walt
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    I have that PDF somewhere. I'll start some full scale searches on my HDD's an post it up if I find it
    Edit: Geez....didn't think i'd find it that quick LOL
    Feb 2006
    Dallas
    kamikaze2112,
    Thanks, that was exactly what I was looking for! This and the other info you provided should get me going. I've got a lot of learning to do still, but think I should be able to put my system together, since it will not be as full feartured as many of the ones I've seen.
    Walt
    Jan 2006
    XM Protocol
    Could someone post some sample VB code using the xm protocol info? I'm new to working with serial data. It's not entirely clear from looking at the pdf how to send the info.
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Your best bet is to check the open source projects on sourceforge.net or the roadrunner source code..
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  1. XM Direct + Serial = Mouse?
    By jpsndtek in forum Hardware Development
    Last Post: 12-23-2007, 01:56 PM
  2. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  3. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 03:07 PM
  4. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
