Results 1 to 7 of 7
Thread: Destinator SDK
    Mar 2005
    Destinator SDK
    I try to make an application, like this:
    Set d3 = New DESTDLLLib.Dest
    d3.ParentWindow = picGps.hWnd
    varRisposta = d3.CreateDestinatorWindow(F_DEFAULT + F_NOCONTROLS + F_NOCAPTION + F_NOSYSMENU)
    If varRisposta = API_COMMAND_IS_DONE Then
    d3.ShowDestinatorWindow
    Else
    MsgBox varRisposta
    End If
    But how can I resize the Destinator windows ?? because when show in my picture, is oversize.
    Tanks
    Luca
    Mar 2005
    Hi,
    I am really without solution , please help !!!
    After to have executed "createdestinatorDialog Addredd_dlg" I have need to resize it and to adapt it to mine skin.
    the lines of code after "createdestinatorDialog Addredd_dlg" come only executed after the closing of the addreassdialog.
    Can I have some line of example to made this.
    Thank you
    Luca
    Feb 2005
    your going to have to invoke FindWindow and SetWindowPos Windows API calls, at least that is how i did it when fooling around with it in C#. I have the code at home i'll try to post it if i remember
    Mar 2005
    The first post is Ok, the second is the pronlem!
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    you need to resize the destinator map size before you call the address dialog.. as the address dialog always appears the same size as the map. You will need to use the setwindowpos api call as mentioned above to alter the size after this.
    CdR
    Mar 2005
    Thanks for the solution, so it works!.
    If I perform the code, line for line (F8) all ok, if I start the project (F5) doesn't perform the resize!
    I have Already tried to position the various doEvents.
    How can I hide the caption and the superior menu of the address_dlg?
    Thanks for the shown patience.
    Luca
    Apr 2006
    Hi Luca (it seems to me that you are Italian...)
    However I'd like to know if u can post some code lines....
    thanks a lot!
    (Il mio problema è far comparire la finestra address_dlg all'interno di una picture e quindi non nell'intero form....)
