Here is a little bit of VB.NET code I wrote a while ago to list the available SSID's. This only worked once Windows Wireless Config had picked up the list of networks though, so not sure how much help it will be.
Code:
Imports System.Management
Imports System.Text
Imports System.IO
Public Class Form1
Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'Form overrides dispose to clean up the component list.
Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing Then
If Not (components Is Nothing) Then
components.Dispose()
End If
End If
MyBase.Dispose(disposing)
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
Friend WithEvents lblHomeNetwork As System.Windows.Forms.Label
Friend WithEvents lblAvailable As System.Windows.Forms.Label
Friend WithEvents btnSearch As System.Windows.Forms.Button
Friend WithEvents lstAvailable As System.Windows.Forms.ListBox
Friend WithEvents txtHome As System.Windows.Forms.TextBox
Friend WithEvents statusBar As System.Windows.Forms.StatusBar
<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
Me.lstAvailable = New System.Windows.Forms.ListBox
Me.txtHome = New System.Windows.Forms.TextBox
Me.lblHomeNetwork = New System.Windows.Forms.Label
Me.lblAvailable = New System.Windows.Forms.Label
Me.btnSearch = New System.Windows.Forms.Button
Me.statusBar = New System.Windows.Forms.StatusBar
Me.SuspendLayout()
'lstAvailable
Me.lstAvailable.ItemHeight = 16
Me.lstAvailable.Location = New System.Drawing.Point(12, 88)
Me.lstAvailable.Name = "lstAvailable"
Me.lstAvailable.Size = New System.Drawing.Size(219, 100)
Me.lstAvailable.TabIndex = 0
'txtHome
Me.txtHome.Location = New System.Drawing.Point(12, 40)
Me.txtHome.Name = "txtHome"
Me.txtHome.Size = New System.Drawing.Size(219, 22)
Me.txtHome.TabIndex = 1
Me.txtHome.Text = ""
'lblHomeNetwork
Me.lblHomeNetwork.Location = New System.Drawing.Point(12, 19)
Me.lblHomeNetwork.Name = "lblHomeNetwork"
Me.lblHomeNetwork.Size = New System.Drawing.Size(219, 19)
Me.lblHomeNetwork.TabIndex = 2
Me.lblHomeNetwork.Text = "Home Network:"
'lblAvailable
Me.lblAvailable.Location = New System.Drawing.Point(12, 68)
Me.lblAvailable.Name = "lblAvailable"
Me.lblAvailable.Size = New System.Drawing.Size(219, 19)
Me.lblAvailable.TabIndex = 3
Me.lblAvailable.Text = "Available Networks:"
'btnSearch
Me.btnSearch.FlatStyle = System.Windows.Forms.FlatStyle.System
Me.btnSearch.Location = New System.Drawing.Point(68, 196)
Me.btnSearch.Name = "btnSearch"
Me.btnSearch.Size = New System.Drawing.Size(107, 31)
Me.btnSearch.TabIndex = 4
Me.btnSearch.Text = "Search"
'statusBar
Me.statusBar.Location = New System.Drawing.Point(0, 244)
Me.statusBar.Name = "statusBar"
Me.statusBar.Size = New System.Drawing.Size(245, 22)
Me.statusBar.TabIndex = 5
'Form1
Me.AutoScaleBaseSize = New System.Drawing.Size(6, 15)
Me.ClientSize = New System.Drawing.Size(245, 266)
Me.Controls.Add(Me.statusBar)
Me.Controls.Add(Me.btnSearch)
Me.Controls.Add(Me.lblAvailable)
Me.Controls.Add(Me.lblHomeNetwork)
Me.Controls.Add(Me.txtHome)
Me.Controls.Add(Me.lstAvailable)
Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
Me.MaximizeBox = False
Me.Name = "Form1"
Me.SizeGripStyle = System.Windows.Forms.SizeGripStyle.Hide
Me.Text = "WirelessMan"
Me.ResumeLayout(False)
End Sub
#End Region
Dim bFoundNetworks As Boolean = False
Private Sub SearchNetworks()
lstAvailable.Items.Clear()
lstAvailable.Items.Add("Searching...")
Try
Dim query As String = "SELECT * FROM MSNDis_80211_BSSIList WHERE Active='True'"
Dim searcher As ManagementObjectSearcher = _
New ManagementObjectSearcher("root/WMI", query)
Dim moc As ManagementObjectCollection = searcher.Get()
Dim moe As ManagementObjectCollection.ManagementObjectEnumerator = moc.GetEnumerator()
moe.MoveNext()
Dim objarr() As ManagementBaseObject = CType(moe.Current.Properties("Ndis80211BSSIList").Value, ManagementBaseObject())
For Each obj As ManagementBaseObject In objarr
bFoundNetworks = True
Dim ssid() As Char = Encoding.ASCII.GetChars(CType(obj("Ndis80211Ssid"), Byte()))
lstAvailable.Items.Add(New String(ssid))
Next
If lstAvailable.Items.Count = 0 Then
lstAvailable.Items.Add("No networks found!")
End If
Catch ex As ManagementException
' Wireless device disabled
lstAvailable.Items.Add("Wireless device disabled!")
Catch ex As System.NullReferenceException
' Windows hasnt searched for wireless networks yet
bFoundNetworks = False
lstAvailable.Items.Add("Windows must search...")
End Try
End Sub
Private Sub CheckShare(ByVal strPath As String)
'Inherits System.IO.FileSystemInfo
Dim mobjFileInfo As FileInfo
Dim mobjDirectoryInfo As DirectoryInfo
Dim mblnIsDirectory As Boolean = True
Try
mobjDirectoryInfo = New DirectoryInfo(strPath)
Catch ex As Exception
Console.WriteLine(ex.ToString())
End Try
If mobjDirectoryInfo.Exists Then
MsgBox("share exists!")
Else
MsgBox("share doesnt exist!")
End If
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
txtHome.Text = "Please select a network..."
'SearchNetworks()
CheckShare("c:\Mp3")
CheckShare("\\Terabyte\200gb (c)\MP3")
End Sub
Private Sub btnSearch_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnSearch.Click
SearchNetworks()
End Sub
Private Sub lstAvailable_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles lstAvailable.SelectedIndexChanged
If (bFoundNetworks) Then
txtHome.Text = lstAvailable.Items.Item(lstAvailable.SelectedIndex)
End If
End Sub
End Class
