Results 1 to 10 of 16
Thread: frontend developers - forms and menues
    Low Bitrate Mcnovy's Avatar
    Feb 2005
    Denmark
    Hey.
    im making my own front end, but i have a Q. for other developers of front-end.
    the way im about to do it, is (by the way its C#) i got a form, and in that form, i use usercontrols to be used as menu's.
    how do others do it..
    ex code, og just explanations would be great.. thanks
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    May 2006
    Quote Originally Posted by Mcnovy
    Hey.
    Can you make a quick paint image of what you are trying to do? Why are you using user controls as menus? There is a built in menu control. It is in the System.Windows.Forms name space.
    Apr 2006
    Dallas, Texas
    He's probably wanting to create an interface that is skinnable and uses graphics for the buttons. There are a few ways to do this. Is this what you are trying to accomplish?
    Feb 2005
    Denmark
    Ineffigy
    yes.. that is exactly what i am trying to
    do any of you have an prober way to do it..?
    CarPC Specs.
    Nov 2006
    Apr 2006
    Dallas, Texas
    You might want to look into "Owner Drawn" controls. This allows you to have control over how the controls (buttons, drop down menus , etc) are created. Another idea is to generate your own controls using DirectX. This will allow for hardware acceleration and alpha blending techniques. It all depends on how fancy you want to get.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    a simple way would be to work on an image, and have a file that defines clickable areas. To begin with, you can have one image. then you can start adding images that are hidden, and the button you press, reveals that part of the hidden image and so giving the illusion of animation.
    this would be a much better way than to use a form. however, for rapid develipment (and you can worry about skinning later) you can use a form, but make sure you dont' embedd too much into the actual buttons, and just have the buttons calls methods. in that way, when you do implement the code for a skin, you can point the click-over to the method.
    hope that helps
    Apr 2006
    Dallas, Texas
    Why not go a step further and have an XML file that defines each object, the properties (aka images) of the object and the method to be called from being "clicked" on or any other event. This way the screen becomes totally customizable and you can work on the background processing instead of focusing on the interface.
    FLAC sama's Avatar
    Feb 2006
    London, UK
