Results 1 to 6 of 6
Thread: Can't full floating point lon/lat out of MapMonkey
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    Can't get floating point lon/lat out of MonkeyTalk.dll in Delphi
    I am trying to make my own lon/lat logger for mapmonkey, because the current one is fixed to 10 seconds.
    After a while I managed to get the .dll working and reading data from MapMonkey. But when I'm getting the lon/lat coordinates it is converting them to numbers instead of full floating points.
    This is how I coded it and what i got:
    Memo1.Lines.Add('Lat: ' + floattostrf(MonkeyMessenger1.Latitude,ffFixed,15,8 ) + ' Lon: ' + floattostr(MonkeyMessenger1.Longitude));
    Result: Lat: 52,00000000 Lon: 4
    I tried to convert it using the format with floattostrf() and with floattostr() but I got no luck.
    What am I doing wrong? Thanks
    Maximum Bitrate DeltaFX's Avatar
    France
    Is this delphi ?
    Depending on your OS, you could use xport or Gpsgate to duplicate your comport, then read that duplicated comport with yourown app.
    Do you have a link to the doc for this dll ?
    Now Galileo is real. Muhahahahaha :p
    Dec 2004
    Netherlands
    Its just MonkeyTalk.dll in Delphi (7.0). Comport splitter will only be more work.
    The Lat/lon is just ready to grab but for some reason im getting rounded numbers instead of real/double/float.
    France
    I don't use MapMonkey, that why I asked for a doc about that dll.
    May 2006
    I was attended to this thread after posting my own, but here's the solution:
    MonkeyTalk only reporting limited GPS coords?
    Dec 2004
    Netherlands
    Yes, that got it fixed, thanks
  1. Replies: 4
    Last Post: 01-29-2005, 07:35 PM
