Results 1 to 9 of 9
Thread: Setting winamp volume via API in VB6
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    I'm trying to set the volume in winamp via an API call. I can see, via debug mode, that FindWindow gives hwndWinamp a six digit number (seems good?) and that SendMessage returns 0. The thing is, nothing happens?
    Code:
    'Declare SendMessage
    Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" _
        (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, _
        lParam As Long) As Long
    'Declare FindWindow
    Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" ( _
        ByVal lpClassName As String, ByVal lpWindowName As String) As Long
    Private Sub Command1_Click()
        Dim hwndWinamp As Long
        Dim tmp As Long
        hwndWinamp = FindWindow("Winamp v1.x", vbNullString)
            If hwndWinamp = 0 Then MsgBox "Couldn't find Winamp"
        tmp = SendMessage(hwndWinamp, WM_USER, 122, 122)
    End Sub
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    I'm not great with VB6 but I'm gonna try to help you anyway.
    First of all, everthing if referenced to this page.
    Looking through your code I couldn't find any value of WM_USER.
    It's a constant and must be equal to 0x400 (In VB: &H400).
    OK, now, to set the volume to a desired value between 0 and 255:
    Code:
    SendMessage(hwndWinamp, WM_USER, <volume>, 122)
    To increase volume by an increment of 1%:
    Code:
    SendMessage(hwndWinamp, WM_COMMAND, 40058, 0)
    To decrease volume by an increment of 1%:
    Code:
    SendMessage(hwndWinamp, WM_COMMAND, 40059, 0)
    *NOTE: WM_COMMAND = 0x0111 (In VB: &H111)
    Enjoy!
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Jul 2004
    Sweden
    I changed the code to this:
    Code:
    Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" ( _
        ByVal hwnd As Long, _
        ByVal wMsg As Long, _
        lParam As Any) As Long
    'Declare FindWindow
        ByVal lpClassName As String, _
        Dim tmp As Long
        Dim WM_USER As Long
        WM_USER = &H400
        Dim WM_COMMAND As Long
        WM_COMMAND = &H111
        tmp = SendMessage(hwndWinamp, WM_USER, 150, 122)
    End Sub
    But it still doesnt work. Thou
    Code:
    SendMessage(hwndWinamp, WM_COMMAND, 40048, 0)
    works. (next file) Strange =/
    Apr 2005
    There must be a problem with your VB code (I don't know enough to help you there).
    Here's how the program is written in AutoIt:
    Code:
    Const $WM_USER = 0x400
    Opt ("WinTitleMatchMode", 4)	;Sets the mode to 'classname=*' titlematch
    $WAhandle = ControlGetHandle("classname=Winamp v1.x", "", 0) 	;Gets the Winamp Handle
    If @error = 1 Then
    	MsgBox(16, "Fatal Error:", "Winamp not found.")
    	Exit
    EndIf
    $input = InputBox("Enter Volume:", "Please enter the volume you wish to set" &@CRLF&"(0 - 100%):")
    If $input >= 0 AND $input <= 100 Then
    	DllCall("user32.dll", "int", "SendMessage", "hwnd", $WAhandle, "int", $WM_USER, "int", ($input*255/100), "int", 122)	;Set the Volume to $input * 255 / 100
    Else
    	MsgBox(16, "Fatal Error:", "Value entered is not valid.")
    	Exit
    EndIf
    And here's the compiled exe file.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    go grab the RR source code, in there you will find a module which will allow you to do everything you want within winamp.
    CdR
    Apr 2005
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    Yes!
    It's called 'WinAMP_Control' -- I'm still using it as a reference every once in a while.
    Jul 2004
    Sweden
    Well, since the AutoIT code worked, I'll just stick with it. Thanks! =)
    Sep 2006
    Winamp control source code for VB6
    There is another example at http://www.industrialmightandlogic.com. Its really designed to work with Input / Output cards like the velleman k8055 or k8061 but the core of the code is simple enough (all the winamp operations are wrapped into a single class). You may want to take a look at it.
    Apr 2008
    solution
    add the word"ByVal" in the SendMessage declaration:
    ...ByVal lParam As Long
    then it should work.
  1. Replies: 6
    Last Post: 11-12-2003, 09:57 PM
  2. How to remove winamp AVS border. - Sample VB6 code
    By Fusion-One in forum Software & Software Development
    Last Post: 10-03-2003, 07:55 PM
  3. winamp volume settings help
    By Stine161 in forum Software & Software Development
    Last Post: 07-29-2003, 10:19 PM
  4. Remember volume setting; Arist name
    By hotwater9 in forum ME Archive
    Last Post: 03-14-2003, 01:43 PM
  5. Setting windows default volume
    By surfer6262 in forum Software & Software Development
    Last Post: 08-16-2002, 02:10 AM
