Results 1 to 10 of 16
Thread: C programmer needed for bluetooth app
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I am after a simple program coded in c to be able to poll for bluetooth connections and be able to connect / disconnect either headset or audio gateway... now the widcomm bluetooth SDK is downloadable free from http://www.broadcom.com/products/bluetooth_sdk.php you only need to reg. The reason I cant do it myself is I dont know the first thing about C and all the examples given are in C ...
    What I want to do is connect to a headset / audio gateway when I dial out from my pc. Even a simple command line app would do, but if a dll or something could be wrote so I can do it in VB even better.
    hope someone can help
    CdR
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    I found something that may help, "Bluetooth Remote Control for SmartPhone" on "Channel9", http://channel9.msdn.com
    Here is some source: http://mtaulty.com/downloads/Bluetoo...trolSource.zip and the article: http://mtaulty.com/CommunityServer/b...2/07/5055.aspx
    Low Bitrate Supergong's Avatar
    Jan 2006
    Germany
    Had a look on the sdk and a sample-application named "BlueHeadphone" is provided! What else do you need? i compiled it without problems....not tested yet cause my dongle is in the car! Perhaps i could help you...
    Supergong
    Feb 2004
    Manchester
    All I'm after is to be able to connect to either the audio gateway or headset from within freefone.. so even a command line app something like autoconnect.exe connect or autoconnect.exe disconnect I'm unsure how it polls for connected devices available connections etc.. but thats the idea behind it.
    CdR
    Low Bitrate Cruelkix's Avatar
    May 2006
    Denver, CO
    I'm very interesed in the same thing. However, I am in the same boat in that I have no C Programming capability. In fact if someone figured this out I think there would be a whole lot of people that would want it just as a quick solution to using their BT phone without having to use phoneco or freefone or rrmobile.
    I just want an executable that I could set a button up on my skin to run and just connects my bluetooth audio gateway. I'm currently using a hack job of an autoit program that just mimicks mouse clicks ...its lame and not very smooth.
    AMP Creator aychamo's Avatar
    Jun 2006
    A common theme on this message board is people begging programmers to do things. Why dont they just learn to program themselves? Remember the old saying "Give a man a fish and you feed him for a day. Teach him how to fish and you feed him for a lifetime" ?? People aren't born with the knowledge to program, they acquire it. Anyone can do the same
    Raw Wave
    Jun 2004
    On the beach
    Quote Originally Posted by aychamo View Post
    Cdrs programming knowledge is all self taught - he has taught himself both vb and flash, he has written many things including:
    • Freedrive
    • Freefone
    • His control pad software
    • All the numerous flash skins which push the boundaries every time
    I applaud cdr for how much he has learnt in the last few years and have worked along side him on Freedrive. I think it unfair to tell him to learn, he was simply asking if anyone had the knowledge to help create some code to allow him to put more into Freefone and push the boundaries once again and has always been the first to try to learn himself before asking others.
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    "push boundaries"
    i wouldnt go that far.
    i would help but it been a while since ive used c last.
    too lazy to deal with all hte syntax errors from java to c.
    haha
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Here is some command line scripting thing for PPC's,
    http://www.vijay555.com/index.php?Releases:VJVolubilis
    It's off your board
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
    Jan 2007
    Very experienced C programmer
    Can program anything you need. Please contact me if still interested.
    Thank You.
  1. Multiple instances of an app starting up
    By ragnarok in forum Road Runner
    Last Post: 09-01-2006, 03:58 PM
  2. App goes straight to toolbar
    By thanatos106 in forum SkinBedder
    Last Post: 08-19-2006, 03:13 AM
  3. CdRsKuLL's Beta D3 Frontend.. Testers needed
    By CdRsKuLL in forum Software & Software Development
    Last Post: 01-23-2005, 06:26 AM
  4. Amplifier Needed?
    By c0rrupti0n in forum Newbie
    Last Post: 03-15-2004, 04:04 AM
  5. Skin Needed for FrodoPlayer
    By frodobaggins in forum Software & Software Development
    Last Post: 07-03-2003, 03:53 AM
