So no one knows of any already built drivers/code for this?
I was really hoping to avoid doing it myself
But if I end up writing an emulator, would anyone else be interested in it?
Using the UPS parts, you WOULD have an external voltmeter, and standard HID class battery/ac reporting. I'm not a programmer (though I did stay at a holiday inn, and do have a Unix/C/C++ associates degree)
I hate programming. I can try to fix/mod others, but can't create my own![]()
91 Stealth RT/TT
CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
Display: Lilliput 7" Touchscreen
I'd definately be interested in your idea. I'm not much of a programmer, more of an electronics tech. I was looking to do the same, only by using a small 12volt PLC. That's the only way I could accomplish that. That's a big expense, however, but provides a good control interface for the vehicle.
Are you looking to start the vehicle at a point where the voltage is low for a set period of time (as an additional step in your software)? I can see that being advantageous in applications where the puter stays on long-term, for purposes like remote comms/ control.
Okay, Ive already started on this little project.
It's going to involve writing device-drivers (which I hate),
but I should hopefully have it done it a week or two.
I'll keep anyone interested posted on the progress!
Good Luck![]()
Would this help at all?
http://www.mp3car.com/vbulletin/show...3&postcount=21
~ Joel
I'd actually be quite interested in this, any luck getting it going?
Holden VY Calais 5.7lt LS1 V8
Computer:
MB896 Pentium M Mini-ITX Motherboard, Intel Pentium M 750 1.86 GHz, 1Gb DDR2 Ram, 250GiB SATA, Xenarc 800TSV 8" VGA Monitor with touchscreen, GPS/Cellular/PCS/WiFi antenna, Bluetooth GPS, etc ,etc
Thanks jnorion,
Thats kinda along the lines of what we're looking for, but something much for detailed. Where you can actually get the _level_ of the battery, too.
Rowan,
Ive started a bit on the project but kinda abandoned it lately because Ive had zero free time. But Im jumping back on it so hopefully I'll have something usable soon!
