+ Reply to Thread
Results 1 to 10 of 13
Thread: Windows Speaker Setup
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    I am trying to programatically be able to change the Windows Speaker Setup in the control panel. Ex: Stereo Speakers, 5.1 Surround, etc... Anyone know if this is possible. Is there a windows registry entry for this? Is it sound card specific?
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    Sep 2006
    Cornwall, England
    I havn't heard of any way that this can be changed, other than through the control panel. What exactly are you wanting to change this for, because I have found that when you change (for example) from 5.1 output to stereo output, you have to do a reboot for the change to take effect. I think that the information is stored in the registry, but where, I don't know. You could have a look on Google.
    May 2003
    Louisiana
    I will have to check on if it requires a reboot.
    I found these registry keys on my laptop, but I'm not sure if they are hardware dependent.
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Hardware\Profiles\Current\System\CurrentControlSet\Enum\PC I\VEN_1002&DEV_4370&SUBSYS_309113C&REV_02\3&13C0B0 C5&0&A5\DirectSound\Speaker Configuration
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Hardware\Profiles\Current\System\CurrentControlSet\Enum\PC I\VEN_1002&DEV_4370&SUBSYS_309113C&REV_02\3&13C0B0 C5&0&A5\DirectSound\Speaker Type
    The values do change when the speaker configuration is changed.
    Nov 2006
    The way to change it is via DirectX functions.
    May 2003
    Louisiana
    Can you point me out to these DirectX functions? I don't have much experience with DirectX.
    Sep 2007
    7.1 wide configuration speakers
    (Sony Dynamic Digital Sound (SDDS) 1993 - Depriciated!)
    Speaker Type: 12
    Speaker Configuration: 7
    FivePointOne: False
    GeometryMax: False
    GeometryMin: False
    GeometryNarrow: False
    GeometryWide: False
    Headphone: False
    Mono: False
    Quad: False
    SevenPointOne: True
    Stereo: False
    Surround: False
    7.1 home theater speakers
    Speaker Type: 13
    Speaker Configuration: 8
    FivePointOne: False
    GeometryMax: False
    GeometryMin: False
    GeometryWide: False
    Headphone: False
    Mono: False
    Quad: False
    SevenPointOne: False
    Stereo: False
    Surround: False
    5.1 surround sound speakers
    Speaker Type: 11
    Speaker Configuration: 6
    FivePointOne: True
    GeometryMax: False
    GeometryMin: False
    GeometryWide: False
    Headphone: False
    Mono: False
    Quad: False
    Stereo: False
    Surround: False
    Surround sound speakers (5.0)
    Speaker Type: 10
    Speaker Configuration: 5
    FivePointOne: False
    GeometryMax: False
    GeometryMin: False
    GeometryWide: False
    Headphone: False
    Mono: False
    Quad: False
    Stereo: False
    Surround: True
    Quadraphonic speakers (4.0)
    Speaker Type: 9
    Speaker Configuration: 3
    FivePointOne: False
    GeometryMax: False
    GeometryMin: False
    GeometryWide: False
    Headphone: False
    Mono: False
    Quad: True
    Stereo: False
    Surround: False
    Stereo headphones
    Speaker Type: 1
    Speaker Configuration: 1
    FivePointOne: False
    GeometryMax: False
    GeometryMin: False
    GeometryWide: False
    Headphone: True
    Mono: False
    Quad: False
    Stereo: False
    Surround: False
    Desktop stereo speakers
    Speaker Type: 2
    Speaker Configuration: 1310724
    FivePointOne: False
    GeometryMax: False
    GeometryMin: False
    GeometryWide: True
    Headphone: False
    Mono: False
    Quad: False
    Stereo: True
    Surround: False
    Speaker Type and Speaker Configuration refer to the registry settings and are decimal.
    The rest, is the DirectShow config. To set these values, use a simple C# application (download Microsoft Visual Studio 2005 Express C# first), add in the Managed DirectShow reference (install Managed DirectX SDK first), then do something like this:-
    Microsoft.DirectX.DirectSound.Device dev = new Microsoft.DirectX.DirectSound.Device(Guid.Empty);
    Microsoft.DirectX.DirectSound.Speakers s = new Microsoft.DirectX.DirectSound.Speakers();
    s.FivePointOne = true;
    dev.SpeakerConfig = s;
    dev.Dispose();
    also, don't forget to install http://support.microsoft.com/kb/909441
    ___
    binary64
    www.MeediOS.com
    Dec 2007
    binary64,
    I was able to get the C# program working -- at least as far as setting the SpeakerConfiguration. However, the "Speaker Type" in the registry does not change. Any ideas how to do that generically?
    I mean, I code do it specifically for my computer by writing to the registry to the write place, but on different computers, the PCI information would be different.
    Sep 2007
    Maybe there is no need - try it just using the managed DirectX config.
    I'm on the bit where I want to preview all the different configs - without rebooting.
    Dec 2007
    Sorry, I don't understand what you mean -- could you be more specific? This is literally my first experience with C#. I'm used to writing stuff in perl!
    I added a reference to Microsoft.DirectX.DirectSound (in MS Visual C# 2008 Express), and added the code you have above. For switching to headphones I used "s.Headphone = true" instead of "s.FivePointOne".
    If anyone's interested, I have my programs here:
    http://home.comcast.net/~teridon73/hacks/
    Note that as of right now the programs don't properly set the "Speaker Type", but otherwise seem to work.
    The registry setting method is also demonstrated there, and that seems to work perfectly. I'm just trying the C# method out of curiousity.
    Sep 2007
    What I'm saying is I noted the different "Speaker Type" values because I noticed they were changing but I have no idea what they are for. If it works with just .net (just SpeakerConfiguration) then leave it at that; it works.
    A bit of feedback about whether you HAVE to reboot after changing the settings or not would be appriciated. I have no other DirectX stuff running whilst my project runs..
    I read your blog. Good point about DirectSound3D. Regmon.exe should reveal if that other value gets read.
+ Reply to Thread
  1. Problem reinstalling Windows XP
    By gkas in forum WinNT Based
    Last Post: 05-13-2006, 04:02 PM
  2. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  3. Setup Help
    By trance728 in forum Newbie
    Last Post: 05-07-2005, 04:28 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
