Results 1 to 5 of 5
Thread: Can someone please create this for me?
    Low Bitrate iselfdevi's Avatar
    Jul 2006
    NJ
    After the Minlogon.exe mod, windows doesnt recieve acpi shutdown commands anymore. im sure windows sees the command but it does nothing about it, so, (if possible) can someone make a small program that takes that shutdown signal and use it to manipulate the start/shutdown manual mode(as if i manually pressed the start button then shutdown)?
    I am using a similar program like that now from Starfox but it seems to not let windows enough time to shutdown, but it works perfectly fine if i manually shutdown through the start button, and he seems far to busy to post up a fix for me or open source.
    Anyone up to help me out?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    someone's already done that on here... I'll try to fetch it for you
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Jul 2006
    NJ
    Thanks for the help but i have already stated in the original post of this thread that im using the Starfox work around and its not giving windows enought time to shut down my RoadRunner program causing it to not resume on the mp3 it was last on. Starfax is far to busy to update the fix for me.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    doh! didn't realise starfox was the guy that wrote it!
  1. USB GPS to FME and OS X compatible?
    By lorenwade in forum GPS
    Last Post: 10-18-2006, 04:15 PM
  2. Replies: 6
    Last Post: 08-25-2005, 02:51 AM
  3. Auto Create Playlist
    By liquid_smoke in forum Software & Software Development
    Last Post: 11-02-2004, 03:15 AM
  4. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  5. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
