Results 1 to 2 of 2
Thread: CentraFuse Bluetooth Phone Remote
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    alright, i know a bit of java and i am going to *try* (and most likely fail) at making a bluetooth remote control for centrafuse.
    so, before i fail horribly at coding a remote.... is there one already avalible? and how hard is it to code a remote control program using bluetooth (i;ve never coded anything other than programs that run on the same computer)
    i think i hve two choices for it...
    1) jsut a remote program which connects to centrafuse directly (much better and more efficent
    or
    2) run a secondary program/service which would process the remotes commands and then run a script (i.e. change the song, increase the volume, etc) and have the bluetooth remote connect to that)
    i think i am going to go with option two for now... also, does anyone know of any good bluetooth programming guides? i have no idea how to program something for bluetooth nor much about bluetooth in general
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Depending on what phone you have and whether or not you're using PhoneControl (the phone module integrated in CF) you already have this option. This feature is mentioned in detail here: http://zhorvat.dyndns.org/PCForums/S...spx?ForumID=39
    Skinning to go... VisualDesigner2!
  1. Big bluetooth idea for phone integration
    By tux11 in forum General Hardware Discussion
    Last Post: 07-27-2006, 05:34 AM
  2. Using Windows as handsfree with Bluetooth Dongle and BT enabled phone
    By Blassox in forum Wireless Communications
    Last Post: 07-26-2005, 05:17 AM
  3. fs-motorola v551 phone with sony bluetooth headset
    By faiz_23 in forum Classified Archive
    Last Post: 07-16-2005, 04:35 PM
