Results 1 to 3 of 3
Thread: VB6: Get ContorlID of a Button in an External Application
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Question VB6: Get ContorlID of a Button in an External Application
    I'm in the process of rewriting my plugin from AutoIt to VB6 so it's better compatible with the RoadRunner Front End.
    Here's my issue:
    In AutoIt there's a function called:
    ControlGetHandle - "Retrieves the internal handle of a control."
    This means that I can get the handle of any window and of any control in that window (such as a button).
    That way I could send a Click Message to that button using the SendMessage command.
    Example:
    Code:
    $WAhandle = ControlGetHandle("classname=Winamp v1.x", "", 0) ;Gets the Winamp Handle
    $JFhandle = ControlGetHandle("Jump to file", "", 0)          ;Gets the JTFP Handle
    $JTFBhandle = ControlGetHandle($JFhandle, "", 4918)          ;Gets the Jump to File Button Handle
    With the code above, JTFBhandle is the direct handle to the Jump button on the "Jump-to-File" Window.
    Visual Explanation:
    (It is essential that I am being correctly understood.)
    In Visual Basic 6.0, I can get to the "Jump-to-File's" Window handle, but I can't access the handles of the buttons that are on the window itself.
    See the buttons Enqueue File, Move after current, Jump to file, etc.?
    Their Control ID's are 4919, 4920, and 4918 respectively.
    I need to get to the handles of these buttons based on their Control ID numbers above.
    How do I do it in Visual Basic 6.0?
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Low Bitrate Pishaa's Avatar
    Oct 2005
    Look at GetDlgItem API help.
    Raw Wave lostreception's Avatar
    NY
    yea thats what i used for IGQ there was alot of extra stuff going on as well tho
    Code:
    if (getdlgitem(blah) = true AND getparent("winamp") = true)
    then match=1
    syntax is probably off but getdlgitem is not as powerful as autoits getcontrolid
    so you need to make a similar function to check for the same things otherwise it find all sorts of weird windows and controls
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  1. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  2. External Application
    By tn6478 in forum StreetDeck
    Last Post: 01-11-2007, 11:05 AM
  3. How to make MP3 button launch external app?
    By Griffin_Dodd in forum MediaCar
    Last Post: 04-01-2004, 11:04 AM
  4. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 02:16 PM
  5. Mediacar V1.8.3
    Last Post: 01-07-2004, 02:26 PM
