Results 21 to 30 of 31
Thread: OBD Gauges required for RR
  1. #21
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Just ordered this and its is now on special offer
    With the MP3Car discount, it only works out at $21.21. Looking forward to integrating it into RoadRunner now
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  2. #22
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Keep me posted!
    Cheers, Bos
  3. #23
    Oct 2007
    i purchased this too can not wait for RR integration!
  4. #24
    Sep 2005
    Looks like i have succedded in embedding DashCommand
    Looks pretty good IMO.
    Just one thing i would like from DashCommand (if PPE - Brian is viewing) is it possiblt to have another 'option' box which removes the top title and menu bar. If i embed in 'full screen' mode, it doesn't embed properly. So an option to remove the menu and title bar will tidy it up nicely i think since there are no real benefits to having that bar visible.
    Cheers.
  5. #25
    Oct 2007
    Tissy,
    Awesome! What skin did you embed in to did you try DFX? I would love to give it a shot if you can share?
    Sep 2005
    Thanks dmistry !
    The base Skin is called Simplistique, however, it has since it was developed some considerable time again, been heavily moddified and built on by me.
    What skin are you using and how confident are you about skin building.
    More than happy to share what i have done, its what this site is all about.
    The other option is that i lay the skin out for you.
    For those who know how to skin edit, you will need the following.
    Create a skin page with a predefined "Application" area.
    Here is an example of such, call it obd.skin
    MEDIACAR Skin
    MEDIACAR MM Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B21,1,523,110,79,"CLOSE","Exit"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,283,31,74,35,255,102,0,18,"Digital Readout Thick Upright:B","REMAININGTRACKTIME",""
    L02,6,31,268,35,255,102,0,18,"Digital Readout Thick Upright:B","/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
    /, A, x, y, w, h, color R;RGB, G, B
    A01,0,81,800,440,000,000,000
    /, I, x, y, w, h, Code;INDICATORCODES
    /, Y, Back Slider file path
    Y01,"\volume_slider\volume_*.jpg"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    END
    This will give you a basic skin with a close button and also track names etc.
    Then, add a button to your main 'menu.skin' and have the 'command' field labelled as:
    "LOAD;obd.skin;DashCommand;C:\Program Files\DashCommand\dashcommand.exe;!wxWindowClassNR"
    Obvioulsy, the 'C:\Program Files\DashCommand\dashcommand.exe' needs to be where the where YOUR DashCommand exe is stored.
    I haven't tried it in the car yet, but see no reason why it won't work.
  7. #27
    Jul 2007
    FR/4wd gauge
    Hello Tissy,
    Is that gauge for FR vs 4wd torque active? Just curious if it can differentiate between individual wheels and not just Front vs. 4WD. I have AWD and would definitely be interested in setting this for my carPc.
    Thanks,
  8. #28
    Jun 2003
    Memphis - TN
    Seconded. I have AWD, and power shifts front to back. Also, can the Boost gauge display PSI ?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  9. #29
    Oct 2007
    nice I am no good with skinning but hopefully John from DFX will pick up on his thread and throw something together for DFX3
  10. #30
    Sep 2005
    dmistry - Hopefully the above code will be of assistance to the skin creator.
    mpman & custommx3 - Sorry for the confusion guys, the OBD gauge is an example as provided by PalmerPerformance for DashCommand. The purpose of this post was to show that DashCommand can be integrated. Next stage is to create a DashCommand gauge skin for my purposes.
  1. G Series Vans Look here. DASH GAUGES (BACKLIT)
    By ChevyG20SS in forum General Hardware Discussion
    Last Post: 09-12-2007, 03:12 AM
  2. OBD Port on Cavalier not Working!
    By rogergolf in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-01-2007, 10:31 AM
  3. OBD or special hardware?
    By Jirka Jirout in forum General Hardware Discussion
    Last Post: 03-04-2007, 06:01 AM
  4. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
