Page 15 of 31 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 304
Thread: Digital Gauge Software
  1. #141
    Variable Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    I've just read about Dashcommand using remaining CPU performance to optimise the application, Anyhow, I've ordered a licence using PPE kind offer of discount to mp3car users.
    Thanks PPE,
    Dave
    Vauxhall Astra SXi Car PC installed.
  2. #142
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    FYI, i run dashcommand with 6 gauges (nissan skyline), igo8 gps, winamp with vis enabled, and carnetix psumoni etc, all at the same time on an AMD BE2350CPU/1GB ram with no performance issues or skipping....
  3. #143
    Mar 2005
    Norfolk UK
    Quote Originally Posted by pcpete View Post
    Thanks for the feedback Pete. That's good to hear your Car PC isn't compromised. My licence has arrived and I hope to install into Car over the weekend.
    Has anyone got any tips for multi-dash selection integration into RR i.e aspbpm's gauges?
    Thanks everyone,
    Dave
  4. #144
    Mar 2008
    Toronto Canada
    Multidash isn't in current release , but Brian of palmer has been hinting that this feature is iminent....that and scripted pid support eg mpg support, are the 2 features I,m hoping for.
  5. #145
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hey thunderfox10
    U still working on the gauges project or have u given up...
    The little glimpse of the gauges u have shown us looks gr8... So We hope u r nearing it for a release or something
    Cheers !!!!!
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  6. #146
    Mar 2005
    Norfolk UK
    Quote Originally Posted by asmpbm View Post
    Most of PIDs are named the same way in all cars, like SAE.RPM, but other pid, maybe are not avaliable, or are name in different way.
    Could I ask you where the scripts should be placed? Are these key to activating PIDs?
    Many thanks,
    Dave
  7. #147
    Newbie zeusenergy's Avatar
    May 2008
    After a lot of time working on GTR Gauges, finally I can show you how it looks like. There are specially developed for Mazda RX-8 and with PCMSCAN custom scripts for fuel monitor and more.
    I hope you like it.
    First view called "Speed View"
    Second view called "Fuel View"
    Third view called "Engine View"
    Fourth view called "Fuel Flow View"
    Fifth view and NOT yet finished called "Gear Position"
    I will upload dash when it will be finished.
    All very nice, but you will need to work out the spelling of some of the text in your screens. (efficiency, timing.....)
    2001 New Beetle Sport 1.8T, 14 PSI
    My Youtube Vids
    Active Member of vwvortex.com and newbeetle.org
    1st Carputer install in May, 1999
  8. #148
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Any news on the consult plugin for dash command yet, for us fellas with Older Nissans?
  9. #149
    Newbie asmpbm's Avatar
    Mar 2007
    Hi again. I've working on update for GTR Gauges for DashCommand/PCMSCAN.
    I hope BrandomPPE include the features I told him about add "Next/Prev tabs", and "GoTo Tab" and we could have something working like this.
    I hope you like it.
  10. #150
    Nov 2007
    Sydney, Oz
    These are really good guages, and I have installed them into my Ford. Naturally the dials require modification to get accurate figures, and I am slowly working through these to set them for my car.
    However, only some of the guages are actually getting readings from my DashXL, so it appears that the PID's required are either not present or not switched on.
    This is where I am having problems. For example, the above guage, which records fuel level, appears to call for a PID called SAE.RPM. I was under the impression that PID was for a Tacho, so was a little confused why it would be recorded as the OBD-11 value in the settings.
    Can anyone shed light on this?
    Does the PID need to be recorded in the dashboard object view, or the script?
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
