Page 19 of 32 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 311
Thread: Digital Gauge Software
  1. #181
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    What are the differences between english and metric settings in dash command. Are metric for European readings and english for American readings?
    Etc etc.
    Thanks.
  2. #182
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Difference is between Miles/Kilometers psi/kgf inch/mm etc.
    Correctly speaking it should read Metric (SI - System International which was invented by the French) or Imperial (English) units... Not American or International?!?
    Im pretty sure that Ounces, lbs, miles, yards, feet, and inches etc. where all in use in England before America was even discovered!
  3. #183
    Mar 2007
    Can someone explain to me how I would go about determining what the PID values are for my vehicle. I've got a Subaru Legacy Outback (1998) and I'm trying to use asmpbm's gauge pack (the GTR ones) and the only one that seems to work off the bat is the RPM gauge. I don't really understand what I'm supposed to do. All I understand is that I'm supposed to be changing the PID values using the editor to match whatever values my car outputs...?
    I'm lost, lol. I'm using DashCommand, which I've managed to embed into Centrafuse.
  4. #184
    Maximum Bitrate Davefocus's Avatar
    Mar 2005
    Norfolk UK
    Stang,
    Download the free trial version of PCMScan. Goto the settings tab and select PID config. This will identify the PIDs available, and is the way the the Palmer Performance Engineering team would recommend to you too.
    I had to do several printscreen's as there isn't (or wasn't in the 880 build) an export PID list function. Using the list of PIDs available to your vechicle you can use DashCommand editor to substitute PID IDs. Be warned that the Maxda RX8 (aspbpm's vehicle) will probably have many more PIDs and aspbpm use PCMScan, that supports scripts (I think DashCommand doesn't at present).
    Let us know how you get on! My 2001 Astra had 52 PIDs available.
    Seasons Greetings,
    Dave
    Vauxhall Astra SXi Car PC installed.
  5. #185
    Mar 2007
    Thanks! That's exactly what i needed to hear.
    I know m,y car wont output nearly as much data, but we'll see. Ill let you know what happens.
  6. #186
    Mar 2007
    Well I'm not having much luck. I've done what you said and got my list of supported PIDs but when i edit the DashXL file from, say, SAE.TP_R (which is what it was set to) to SAE.TP (which is what my car supports) I still don't get a reading from it. I know I can read that data because the OBD-II reading software integrated in Centrafuse reads it. I don't know what's wrong...
    I've noticed in PCMSCAN that it says "not scanning unlicensed parameter:" and then lists almost everything. I'm assuming that's because it's unregistered software? Will DashCommand not read these values until i register it either? Is that the problem? I was hoping I could see how many gauges I could get working and how well it worked before I paid for it.
  7. #187
    Mar 2005
    Norfolk UK
    I think that DashCommand, and don't quote me on this, only reads five if not registered - ECT, IAT, MAP, RPM and VSS - likewise PCMScan. These five are the only PIDs ticked on my list from the trail PCMScan used to establish a PID config list.
    I have a file that works with my car after tweaking with aspbpm's. Just PM me your email addy if you want to try that too.
    Also, it may be worth trying the Palmer performance forum for some more detailed help. I'm more than happy to help but I'm no expert I'm afraid .
    Cheers,
    Dave
  8. #188
    Mar 2007
    Alright, well, I'll purchase the software and try again when I have time and see how far I get. If that doesn't get me anywhere, maybe yours will work better than his. Let's see what happens first. Doing the normal PID scan popped up 50-something PIDs available so I think I should be able to get quite a few of them working EVENTUALLY.
    Thanks for all the help!
  9. #189
    Dec 2008
    Plan to integrate DashCommand to RoadRunner. so design the 1-4,A-G as the buttons. Does DashCommand have the commands(button codes) to change it's skin?
  10. #190
    Mar 2008
    Ok let me get this right before I purchase things, for this sort of layout, i need;
    1 CarPC
    2OBD2 Reader
    3the gauge pack listed in this theme
    and then what software do I need, PCScan or dash command, this is where Im confused
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 12:06 AM
