Page 24 of 32 FirstFirst ... 14151617181920212223242526272829303132 LastLast
Results 231 to 240 of 311
Thread: Digital Gauge Software
  1. #231
    Jan 2007
    I would actually disagree with the above on the basis that VAG actually stands for Volkswagen Audi Group , With Seat being just one of its Subsidiaries ( aswell as Lamborghini , Skoda ect). I purchased an ELM Cable for use with other projects and was unsuccessful to connect it with my Golf GTI 1.8t or a friends Seat 1.8t both with 51 Plates on a variety of software. VAG-COM Software and the Cables, Unlike generic OBD-II/EOBD, uses manufacturer-specific commands, which allows the user to access all diagnostic capable vehicle systems. This was cleverly created by using reverse engineering (Ross tech would cause an error code and see what the Vag Cable Reported back to the PC) OBD-DIAG is the only non VAG tool i got working with my golf but with the Serial Version of the VAG Cable, the USB one would not connect. Nimikipod you are correct on the fact that your Ibiza Uses the Exact Same Engine, ECU ect as the GOLF, And i would be very surprised if you got an ELM Cable to Work .
  2. #232
    Apr 2008
    Quote Originally Posted by BOIL_GALPIN View Post
    Dude, unless it's a **** old VAG, an ELM has got to work! The OBD interface and commands are generic, they are a standard, it's not something that this or that company implements while others implement something else. And there's only four varieties of it's implementation:
    PWM, some other that GM uses, EOBD, and CANBUS. And all european cars after 2000 for petrol, and 2003 for diesel are required to have EOBD suppost (as do most japanese cars) or CAN BUS after 2008. This is mandatory by the european laws that limit car pollution and emissions.
    Perhaps you used a defective ELM327, or an ELM323 on your VAG?
    Like I said before, the VAG-COM is a proprietary interface for a proprietary software. They only couple up with each other. If you want to use ELM compatible software, you must have an ELM interface.
  3. #233
    Jan 2007
    Ok so i took your advice and had a look into why my ELM 327 wasnt working.
    And it turns out it Was defective, I did some re-soldering on the Pins and Dash Command Fired up and connected straight away. Cheap ebay crap..
    Thanks Thunderfox ...
  4. #234
    Apr 2008
    That's a pretty common problem... I've had it in the past with my ebay ELM327 too!
    Glad you sorted it out!
  5. #235
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    right, so i saw in the video for dashcommand that you can have different pages. How was this implemented and in what front end. I currently use CF after using RR for a few years and would like to integrate dashcommand.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  6. #236
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Quote Originally Posted by Spawn12336 View Post
    I'm lead to believe this feature is planned in the next (long awaited) update!
    Dave
    Vauxhall Astra SXi Car PC installed.
  7. #237
    Nov 2005
    Toronto, ON
    ah.....crap.... more waiting. ah well. Time to work on a dash that till do what I want in the current confines.
  8. #238
    Mar 2009
    Hey,
    i'm getting very strange readings from my elm327 usb device. the unit gets data but it is all scrambled. as an exampel - the rpm meter goes ballistic once i touch the gas pedal (the actual rpm meter goes to 3000 rpm while the dashcommand's goes to 9000 rpm..
    is there a way to adjust sensitivity ? can i change the calculation ?
    is it a known problem with VW's ??
    thanks
  9. #239
    Apr 2008
    Quote Originally Posted by nimikipod View Post
    Hey,
    thanks
    Some cars have a different multiplier for the RPM function... Usually it's x/4.
  10. #240
    Jan 2007
    San Francisco
    Quote Originally Posted by asmpbm View Post
    After a lot of time working on GTR Gauges, finally I can show you how it looks like. There are specially developed for Mazda RX-8 and with PCMSCAN custom scripts for fuel monitor and more.
    I hope you like it.
    First view called "Speed View"
    Second view called "Fuel View"
    Third view called "Engine View"
    Fourth view called "Fuel Flow View"
    Fifth view and NOT yet finished called "Gear Position"
    I will upload dash when it will be finished.
    Hey, asmpbm! I installed your gueages and they look great! Have one problem though. Hope you know what I'm missing. O2 sensor readings in "Engine View" screan are not show up in dashcommand. Everything works in PCMSCAN though. Do you have any idea?
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
