The .dxls file is a dash set. Download the skin editor, create a new set, click on Dashboard1, then on Edit Dashboard and the dash editor starts. Do a File -> Import From File and load the .dxl file. Save Dashboard, Exit, Save and you have a brand new .dxls file.
Load the scripts in Dashcommand with Settings -> ScriptsQuote:
Question 2: With the new DashCommand, do I get scripts and the "1" to "G" buttons to show and work ?
The buttons will work if they are programmed to work. Download the examples on dashxl.net to see what has already been done.
Not sure about that. I have only seen a single .dxl file import.Quote:
Question 3: I think I read somewhere that I can import the entire .rar file (or zip was it?). Do I zip all these script and dxl files up and import or something?
I attached my quick import of the GTR gauges into a .dxls. In Dashcommand, go to Settings -> DashXL to load a skin set. I added the next/prev buttons and Objects needed from another dashboard on dashxl.net.Quote:
I won't spend $ to by DashCommand if this doesn't work right or at least someone has some solution that works with these GTR gauges. The Lite version has been fun so far but time to move to something better.
You're welcome.Quote:
Thanks.
Dean
