Page 4 of 31 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 304
Thread: Digital Gauge Software
  1. #31
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Quote Originally Posted by S4Per View Post
    looks great! Can you tell me if it will work with a vag-com interface? www.ross-tech.com.
    Thanks,
    Per
    Unfortunately, our software does not support the VAG-COM interface. Our DashCommand software (currently) works with ELM interfaces, and our PCMSCAN software supports many different types, including ELM, J2534, & Autotap interfaces.
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
  2. #32
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    I really do appreciate that it can embed easily, but I am hopeless at figuring that out. It took me 8 months to figure out how to get my ADS USB FM tuner integrated into Road Runner (& still it doesn't work fully). I imagine this would be just as hard. I have my obdii software working on my carpc thru my elm compatible interface, and just use that alone. I imagine a skin as something like what u did above, with the buttons for main menu, simple audio controls, an maybe a song/radio station header at the top, as a file I can remap one of the main screen buttons to. To to create the skin & integrate it into Road Runner is way beyond me... That's why I said, if somebody made a skin of that, I would buy the software, because that is something I can handle. Especially, since it looks like it is 1/2 price now.
    Quote Originally Posted by PPE View Post
    Actually, our DashCommand™ software was designed to be easily embedded into any front end such as StreetDeck or RoadRunner. We have some simple embedding parameters described here.
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  3. #33
    Constant Bitrate C4DAO's Avatar
    Apr 2007
    Cardiff
    Excuse me for not doing my research, but will your hardware work with CANBUS? Specifically a Citroen C4 2005 model. I would be very interested if it did...
  4. #34
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Looks nice but for me is not useable because do not show right values for rpm... When I have 1000rpm this software show 250rpm. I have ELM 237... Is posible where change or delete divider rpm by 4 in software?
  5. #35
    Nov 2007
    Sydney, Oz
    Quote Originally Posted by _Dejan_ View Post
    Is that because your refresh rate is too slow, or becuase you are trying to display too much info at once and the cpu cannot handle it ?
  6. #36
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by alypally View Post
    This is because software when receive data from OBD divide value which receive by 4... Im try connect to OBD with hyperterminal and request rpm and convert value from HEX to dec and I get real values in this software show me values divided by 4... So is posible where configure something like calibration? Because Im looking to buy software which have gauges and I can calibrate values... I can write application(in Delphi) but without gagues, so this don't help me...
  7. #37
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    Here are old pictures of my HalWin Haltech Engine Management Software:
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  8. #38
    Oct 2005
    UK
    Suggest you purchase a copy of PCMSCAN and this will save you a lot of hassle!
    If you want to get from a European Supplier you can download from our web-site (http://www.ukobd.co.uk/gstore/store/...p?idProduct=89)
    Gareth
    UKOBD
  9. #39
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by UKOBD View Post
    Gareth
    UKOBD
    Im try demo when Im buy ELM tool but Im not find something like calibration... As I remember you can chose only metric/imperial PIDs... I will try demo again and if support this I want then I will buy it otherwise not...
  10. #40
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    I believe our software is reporting the correct values - otherwise I think we would have had many many customer complaints over the years.
    In your case, I think I know where the confusion is coming from. You see, the vehicle reports the RPM in quarters of an RPM. So you have to divide by 4 to get the Engine Speed in whole numbers. If you are requesting it manually through hyperterminal, then you are actually seeing RPM times 4.
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
