Page 6 of 31 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 304
Thread: Digital Gauge Software
  1. #51
    Dec 2007
    Jakarta - Indonesia
    Hi PPE ;
    I am new here from Jakarta Indonesia and just buy PCMSCAN with ELMSCAN 5 from Singapore and I will recived at 27 Des 07 so if I need help can I email to U also how to registered the software?
    I want to used wiyh my MAZDA 3 HB 1.6 L A/T Black Metalik also new from Dealer Here in Jakarta-Indonesia.
  2. #52
    Dec 2007
    Jakarta - Indonesia
    Thank's to PPE and Singapore Distributor.......
    I just recived The License Software PCMSAN, and before I already use the demo version. From I get the license so is more thing I can do with the PCMSCAN.
  3. #53
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Quote Originally Posted by copter View Post
    I too need these for turbo boost, exhaust gas temp and rear diff temp.
    Unless you add pressure sensors and extra temp sensors you've got no chance.
    The Nissan systems don't measure boost at all! They measure airflow and air temp.
    Hence why its called a Mass Air Flow system.
    EGT also needs extra electronics and AFAIK isn't going to happen with Nissan Consult hardware... It would be easier fitting a new ECU like a GEMS setup to do what you want
    There's also ECUTalk for gauges
  4. #54
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Just ordered DashCommand and its is now on special offer
    With the MP3Car discount, it only works out at $21.21. Looking forward to integrating it into RoadRunner now
    Lets see if we can get some more great skins designed !
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  5. #55
    Newbie copter's Avatar
    Dec 2007
    Nor★Cal
    Quote Originally Posted by ShawJohn View Post
    If I get the probes from known guage makers is there any way to connect to the PC?
    _____________________________
    06 BLACKTIE LBZ | GRAYSTONE METALLIC | MBRP 4" | AMP STEPS | KMC DIESELS | TOYO M/T'S | NCT/COGNITO 4-6" | BILSTEIN 5100'S | MAG-HYTEC DIFF COVER | HID'S | PPE XCELLERTOR |
    ______________________________________
  6. #56
    Aug 2004
    On the edge!
    Its not been done yet to AFAIK.
    Not unless you're good at programming and have a knowledge of electronics.
    I suppose it could be done using one of those USB relay board thingies
  7. #57
    Sep 2005
    Looks like i have succedded in embedding DashCommand into RoadRunner.
    Looks pretty good IMO.
  8. #58
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    Wow Tissy, that looks great! Care to post the skin files & give a howto?!!?? I think I may have to buy this software now!
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  9. #59
    Sep 2005
    The base Skin is called Simplistique, however, it has since it was developed some considerable time again, been heavily moddified and built on by me.
    For those who know how to skin edit, you will need the following.
    Create a skin page with a predefined "Application" area.
    Here is an example of such, call it obd.skin
    MEDIACAR Skin
    MEDIACAR MM Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B21,1,523,110,79,"CLOSE","Exit"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,283,31,74,35,255,102,0,18,"Digital Readout Thick Upright:B","REMAININGTRACKTIME",""
    L02,6,31,268,35,255,102,0,18,"Digital Readout Thick Upright:B","/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLL-LEFT"
    /, A, x, y, w, h, color R;RGB, G, B
    A01,0,81,800,440,000,000,000
    /, I, x, y, w, h, Code;INDICATORCODES
    /, Y, Back Slider file path
    Y01,"\volume_slider\volume_*.jpg"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    END
    This will give you a basic skin with a close button and also track names etc.
    Then, add a button to your main 'menu.skin' and have the 'command' field labelled as:
    "LOAD;obd.skin;DashCommand;C:\Program Files\DashCommand\dashcommand.exe;!wxWindowClassNR "
    Obvioulsy, the 'C:\Program Files\DashCommand\dashcommand.exe' needs to be where the where YOUR DashCommand exe is stored.
    I haven't tried it in the car yet, but see no reason why it won't work.
  10. #60
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    How long did it take for you to create the guts of that? As in, not the graphical skin itself, but the stuff controlling how those gauges act in response to OBD-ii inputs? I already have a $600 Ford usb/obd-ii scanner/programmer, but am on the fence for a compact read-only unit with this dash command software, but I don't have much time to invest into learning/coding/skinning..
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
