Which cars don't measure boost? Most cars have a map sensor even if it's not highly weighted by the ecu. It's easy to add one if there isn't. Thermocouples are a little more difficult but any tuner worth paying should know how to do those.
Just about every auto sensor reports in 0-5v, there are daughter boxes on the market now that will collect and log this data. I'm not sure how to build something similar to xmit via usb or similar interface. If all you want to do is display it should be as simple as a wafer board and lcd display.
i stumbled into some interesting software when i was looking through all the crap my boss brought back from sema www.magden.us seems to be pretty promising on the eyes, but because they are just releasing their product there is no downloadable software yet, their website does have a download section but it says "coming soon"
at present time it looks like they are selling the whole package as computer and software
How can you say 'most cars have a map sensor'?!?
Mine Nissan's SR20DET hasn't! There are two systems commonly in use today - MAP, and MAF.
My old Rover T16 engine had a MAP sensor, but no MAF sensor, its usually one or the other, not both!
An airflow system has no need to know boost pressure, Boyles law tells us that pressure, volume, and temperature are all constrained to one another so off volume and temperature, pressure can be calculated.
MAF systems are generally more accurate and hence why most modern cars use MAF setups and not MAP systems.
I advise you to go do some reading![]()
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
My motor(LS1) has both MAF and MAP stock - kind of a surprise coming from GM, engineers must have got it by the bean counters somehow![]()
i too have a map and maf sensor on my stilo jtd.
ppe did you figure out why software when run on the jtd shows the wrong figures? as mine seems to show idle at 212rpm and speed at 158mph while standing. i would say it isnt obd compliant but it is a 2005 05 car?? would really like this kind of software but the readings would be useless?
Does anyone know if PPE's Dash XL can be embedded with RR, or do you need Dash Command to do it?
Brian @ Palmer Performance Engineering, Inc.
http://www.palmerperformance.com
DashXL™ is the name of our cutting edge dashboard technology. Both our PCMSCAN and our DashCommand products offer DashXL dashboard support. So you will need to get DashCommand or PCMSCAN to use DashXL dashboards in RR.
-Brian
I have a tuner (programs ECU through OBD-ii) that I currently use to read OBD-ii data... It's an SCT X-calibrator2. Would this be compatible with DashCommand/DashXL, or whatever it is I need to get custom gauges? I have SCT LiveLink which can display some graphs and gauges, but the appearance is not customizable and it's ugly.
Also... after paying $400 for a tuner, I'm a little reluctant to spend another $100+ on a OBD-ii reader if my tuner can already do it...
