The best (easiest) way of doing this using DashCommand would be to install a CarPC with the dual monitor support for your two screens. Then extend the Windows desktop onto both monitors. After that, you should be able to maximize the DashCommand window so that it stretches across both monitors. Once you have that going, it's just a matter of designing a custom dashboard with the correct aspect ratio so that you have the right gauges on each monitor.
LinkBack URL
About LinkBacks
