Results 1 to 10 of 16
Thread: DashCommand v2 is now available!
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    DashCommand v2
    We are proud to announce that DashCommand version 2 is now available.
    DashCommand™ is a touch screen friendly software application that is designed to integrate OBD-II data monitoring and logging into the in-car computing experience. Use DashCommand’s capabilities to create and display stunning virtual dashboards with styles ranging from digital gauges to analog gauges. Thanks to DashXL™ technology, the dashboards look great on any screen size, large or small.
    We’ve added new capabilities to DashCommand that will allow a richer and more satisfying experience. The highlights are:
    • Create and use interactive dashboards with the addition of buttons, states, and the ability to switch between dashboards.
    • Add new calculated metrics to dashboards with the support of ScanXL scripts.
    • Read and clear your Check Engine Light trouble codes.
    • Record data logs from dashboards and from the new data logging screen.
    • Playback the logs files or analyze then in ScanXL.
    • Support for multiple vehicles
    Use the DashXL Skin Editor to create your custom interactive virtual dashboards or modify and customize the ready-made dashboards available for download from DashXL.net. The dream of having a full function virtual dashboard at your finger tips that matches the style of your existing dashboard can now be realized.
    DashXL.net
    Introducing DashXL.net, your source for DashCommand dashboards and resources to help you create, modify and customize dashboards for your particular needs. Over the coming months DashXL.net will grow to include dashboards submitted by DashCommand users that can be downloaded and used by the rest of the community. We hope that the new site will become a valuable resource for those seeking help with creating and modifying dashboards and that together we can build a supportive and active community.
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Congrats once again PPE!! I have been messing around with it for a couple of days now...wow! you guys did alot of work...
    It is a major update!! The skinning , the scripting the logging oh my!! Great job!
    Just a question regarding ..
    Quote Originally Posted by PPE View Post
    DashCommand v2
    Can one put in enhanced pids from your scanxl enhanced pid packages? I'm planning to purchase the Mazda Enhanced PIDS as well as SCANXL...just wanted to make sure...
    Thx once again
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi PPE
    well I have downloaded the trial ver of this software and am testing on my Skoda Car
    Here i just get RPM working properly and the rest of the guages are all dead...
    Can you pls help me with the files so that i can get it to work in my Skoda car...
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Oct 2004
    Israel
    vicky_obee ,
    this is what you get in the demo
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Dec 2003
    Hey thanks for the info...
    What i mean to ask is... IS this software compatible with DashCommand...
    I would love to buy this piece of application IF it works...BUt then how do i know if its compatible or no...
    May be it should ba fully working Demo for 7 / 15 days or so...
    That way atleast we can try it out and see if it suits us or no...
    What say PP !!!!
    BTW is there any other software that can work as a full function ( demo) b4 i by something
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    As Madboy said above, you only get Engine RPM in demo mode. You must purchase a license key to unlock the rest of the PIDs. To see which PIDs are supported by your vehicle, go to the data logging screen and click Add PID. This will bring up a list of total/supported PIDs.
    The fact that you are able to get Engine RPM to show and work properly means the software is compatible and working with your vehicle. You just need to buy a license key to unlock the full functionality.
    Nov 2006
    Will this work for my 2003 yukon denali? I have a Xenarc PC with windows xp.
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Quote Originally Posted by Bromaguire View Post
    Yes, it will definitely work with your vehicle and PC.
    Dec 2003
    Fair Enough PPE
    Ill try the PID function and see if i can make some scene out of it... Also can I change the temp to C instead of F and KMPH instead of Miles....
    Just an add on.. it would have been nice if you could add in ANY other parameter in the demo mode so that it would be very clear to me ( may be others as well ) that the software is fully compatible
    1 more quest .. The license that i buy, will it ALWAYS be active for the particular PC or will I have to buy a new code if I format this PC and reinstall every thing all over again ( no hardware change )
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    The DashCommand dashboards are fully customizable. Just download our DashXL skin editor from our website to edit the dashboard and change it to your liking. Then share it with everyone at DashXL.net!
    If you need to format your computer and reinstall the software, simply save the license key and enter in when you reinstall.
