Results 1 to 8 of 8
Thread: NON-OBDII Engine Diagnostics?
    Aug 2008
    I have a BMW e36 that is getting a Chevy LS1 and I'm looking to run engine diagnostics on my carputer display. I think in the past I've seen a PCI card that has inputs that you can literally just splice electric sender wires into and then you just get software to display the values. Does anybody know where I can find something like this?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Take a look at the Fusion Brain. It is USB and is quite flexible.
    Want to:
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Are you running an ECU on the LS1? If it's ALDL compatable you can get a usb data cable for it.
    RevFE
    My Shop
    Aug 2008
    I guess I didn't really think about this before I asked the question. The engine is going to be taken from a 99-02 Camaro. Since all of those are OBD-II, will there be an OBD-II port on the engine harness or ECU that I can plug into? I'm really sure why I thought I would be running OBDI, maybe because my car is right now.
    Aug 2008
    BTW Mods I posted this in the Dashcommand forum by accident, if you could move it to the general Engine Diag form that would great thanks.
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Since the LS1 is fully OBD-II compliant, as long as you are running the factory ECU that comes with the LS1, you will be able to run our DashCommand software (or ScanXL also) on it. For the LS1, there is only one wire you need to connect to the scan tool (plus power and ground from the battery) to make it communicate.
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
    Aug 2008
    I'll be running the factory ECU. Thanks for the help guys, you just made my life a whole lot easier!
    Jan 2008
    Yeah, luckily the ECU doesn't particularly care what it's in. I have a '92 Volvo 960 Wagon with a 302 out of a '00 Explorer. Sounds like a neat project; it getting a T56 too I hope?
  1. OBDII _Inputs_ & Check Engine
    By jfruser in forum OBDII GPS Logger
    Last Post: 11-13-2009, 02:02 PM
  2. engine diagnostics
    By Heather in forum VaultWiki
    Last Post: 08-31-2009, 05:09 PM
  3. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 08:38 PM
  4. Sludge in Engine
    By Fox_Mulder in forum Off Topic
    Last Post: 06-26-2007, 08:34 AM
