Results 1 to 3 of 3
Thread: Vag to OBD2 cable works with Dashcommand?
    May 2010
    Herákleion, Iraklion, Greece, Greece
    Hey. i have found a cable that makes Vag-com (wich is my car) to OBD2. in that case, and if the car can give speed readings through its diagnostic, will i be able to use dashcommand??
    Sep 2011
    shenzhen,guangdong
    Obd2 drive cycle
    OBD2 Drive Cycle - An OBD2 Drive Cycle is an extended set of driving procedures that takes into consideration the various types of driving conditions encountered in real life. These conditions may include starting the vehicle when it is cold, driving the vehicle at a steady speed (cruising), accelerating, etc. An OBD2 Drive Cycle begins when the ignition key is turned "On" (when cold) and ends when the vehicle has been driven in such a way as to have all the "Enabling Criteria" met for all its applicable Monitors. Only those trips that provide the Enabling Criteria for all Monitors applicable to the vehicle to run and complete their individual diagnostic tests qualify as an OBD2 Drive Cycle. OBD2 Drive Cycle requirements vary from one model of vehicle to another. Vehicle manufacturers set these procedures. Consult your vehicle's service manual for OBD2 Drive Cycle procedures. Do not confuse a "Trip" Drive Cycle with an OBD2 Drive Cycle. A "Trip" Drive Cycle provides the "Enabling Criteria" for one specific Monitor to run and complete its diagnostic testing. An OBD2 Drive Cycle must meet the "Enabling Criteria" for all Monitors on a particular vehicle to run and complete their diagnostic testing.
    May 2010
    didint understood a single think...
  1. obd2 to USB cable + Android Tablet
    By BobTheSavage in forum Android Tablet
    Last Post: 04-15-2012, 06:12 AM
  2. Replies: 13
    Last Post: 04-07-2010, 01:16 PM
  3. OBD2 works with the car off not on?
    By yorky in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-02-2010, 02:11 PM
  4. Help: OBD2 Extension Cable?
    By LarryMZ3 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-19-2008, 05:36 PM
  5. obd2 cable
    By daron in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-06-2006, 04:09 AM
