Results 1 to 8 of 8
Thread: Speed camera detection
    Apr 2007
    I have a file with the lat,long,baring and speed of UK speed cameras. I'm looking at writing a DigiMod that will give a proximity warning based on location and direction of travel Vs the location and bearing of the camera.
    I'de also like to display it on the sat nav map and have an overlay popup in anymode with a warning.
    I've not even started to look at the digimods yet but I've made a skin and I'm an experienced coder so it shouldn't be a problem.
    However I'm on a very tight schedual ATM so to save me hours of research can one of the SD team let me know if this sounds possible and I will then look into it further.
    Thanks in advance.
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I'm interested in this and it sounds possible but I'm not sure... do you know of a place to get the lat, long, baring, and whatever for the speed cams in the US?
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Engine died)
    Work Log v4.5 --> 05 Toyota Tundra DC SR5
    Apr 2007
    unfortuantly no, I only know of a site wiht UK an european cameras listed.
    Constant Bitrate sharpmat007's Avatar
    Nov 2006
    Washington, DC
    You should at the very least be able to import the speed cameras as points of interest using the csv import...check out that thread on importing custom pois.
    Mitsubishi Eclipse 2006 GT
    Infill T3 running StreetDeck
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    You will need to write a custom DigitalMod to do this. The nav object is exposed which has an event that tells you the new latitude and longitude which you can use to show an overlay with your speed camera information. Maintaining and connecting to the speed camera database is something that you will have to do on your own. Besides the database stuff, displaying an overlay based on your latitude and longitude can be done in probably less then 25 lines of code or so. Developer (I am Chuck)
    Get StreetDeck at
    The Official StreetDeck Forums have moved, please visit us at for official support for Streetdeck.
    Jun 2006
    Any movement on this digimod? I would be really interested in having this functionality in SD
    Jul 2007
    This would be a great feature to have, since a stand alone unit costs upward of $200 (
    Any movement?
    Newbie Fama's Avatar
    Jun 2007
    Hi Guys,
    Any movement on this development? Would be great to have this feature on SD.
  1. Replies: 2
    Last Post: 08-31-2005, 06:01 PM
  2. Replies: 5
    Last Post: 02-23-2005, 05:36 PM
  3. Replies: 0
    Last Post: 02-23-2005, 01:40 PM
  4. Speed / Red Light Camera
    By Skorpion in forum Map Monkey
    Last Post: 02-22-2005, 01:44 PM
  5. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 07:13 AM
