Page 10 of 19 FirstFirst 12345678910111213141516171819 LastLast
Results 91 to 100 of 184
Thread: Virtual Earth cache builder? Or even gps simulator to make it cache?
  1. #91
    Sep 2005
    By the way the lat/long functionality is not available. I could not find an easy way to enter the lon and lat on the same page. I dont see that functionality being used any ways so i might just disable the button
  2. #92
    Apr 2007
    Hmm, i get an error when i try to run it. On my home computer i installed the SD Demo, then the 1.1 update, then while running SD I double clicked on your digimod and StreetDeck asked me if i wanted to install it so i clicked install, then i tried to use it and i get this error every time:
    and here is the screen before i get the error, i just put in my zip code, hit save, then click download and the error pops up
    Did I install it wrong or something? This is on windows vista..
    Also, is there any way you can make the slider for tiles larger than a 25 max? Or maybe make it where we can enter a number of tiles in each direction (up, down, left, right) and make that have a bigger max?
    Thanks man, let me know.
    - Mike
  3. #93
    Sep 2005
    I believe you are seeing that error because you did not register the two dlls in the com folder of the digimod script
    run the following command from start->Run for those unfamiliar with registering dlls
    regsvr32 "scriptprojectPath\COM\ZipCodeLookup.dll"
    regsvr32 "scriptprojectPath\COM\ASPtear.dll"
    but if you have registered the dlls. then the issue could be with the createdirectory com object not working with vista. i'll try this on my vista machine tomorrow.
    I tried making the cell to be 99 but it produce a size that was too big to store in a data value in SD. I could probably try to make it as big as 50.
    if you are familiar with modifying code in the development environment, then you can easily change value of the max cell value by searching for
    cellSlider.Max = 25
    on the Module_OnCreate() function
  4. #94
    Apr 2007
    Quote Originally Posted by bembowe View Post
    cellSlider.Max = 25
    I just successfully registered both dlls and it still gives me the same errors, might be something to do with vista. let me know what happens when you try it!
  5. #95
    Apr 2007
    I just tried it on my laptop running XP and I get the same exact error, and i even tried manually registering the DLLS which say they succeeded. Any ideas? Could it be the 1.1.0.0 update? What could i be doing wrong?
    - mike
  6. #96
    Sep 2005
    ok, I just updated mine to 1.1.0.0 and it worked fine. i have only tested this on the development environment as i do not have a carpc to test it on and my trial version has expired. Can you run this in development mode and see if you get the same error?
    also, I dont know if this matters but I also have .net installed. if you havent give that a shot too.
  7. #97
    Apr 2007
    I've got .net on both my machines. I tried it in the dev. environment on my laptop running xp and when i do that the digimod doesn't work right at all. thinks are the wrong place and missing. I dunno, weird that i cant get it to work on either my laptop or desktop.. one running xp, one running vista all with the same error. Im confused!
  8. #98
    Sep 2005
    I would say delete the digimod folder and reinstall the digimod. by the way, how are you installing your digimods, do you already have SD open before double clicking on it or dragging it?
    now when you perform a search does it error out? or is it after you click on download. does it stop anywhere in the code when u run it in dev mode. try it on your xp machine
  9. #99
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Im testing it out right now... working 100% so far, grate work and thank you.
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  10. #100
    Apr 2007
    Well, i tried double clicking the digimod before opening SD and all it did was open SD. So then i double clicked it after SD was open and it gave me the screen with the option to install, it installed it and then asked if i wanted to use and i said yes, then i tried it and it didnt work. I also tried restarting the computer and updating .net to the newest. I also tried draggin the digitmod and reinstalling it in sd that way, no go still. No clue what i am doing wrong and why it doesnt work on either my laptop (xp) not my desktop (vista). I also tried running it in testmode and that didnt help. SD isn't registered on either of these computers, its the trial, could that be the problem?
    - Mike
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  3. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  4. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  5. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
