Page 11 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 101 to 110 of 184
Thread: Virtual Earth cache builder? Or even gps simulator to make it cache?
  1. #101
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    I haven't had a chance to look over the code but my guess is (this is with out any knowledge of how this is coded) that you are missing a directory or something of that nature... try going to a place on your map with virtual earth enable so it can make the necessary directories and try the digimod again
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  2. #102
    Sep 2005
    Redmond, WA
    Try precaching something first with SD itself, i.e. go to the map and click the Virtual Earth button, then go back to the digimod and try again...
    Bembowe, isn't this off by one?
    index = InStr(1,path,"StreetDeck")
    getVEPath = Mid(path,1,index + 10) <-- do you want 11 here
    Or atleast add a trailing "\" It's been a while since I did any VB code so I am not sure if this is off or not, just thought I'd ask...
    Awesome job, by the way, my computer is not exactly cooperating but screenshots looks sweet - I will try it out first thing tomorrow!
    p.s. you shouldn't need .net for this, afaik.
    p.s.s. that digimod screen shot during installation is of the sd dev environment, is that just because you did not have enough time?
  3. #103
    Jun 2007
    I'm also having a problem, i have reg. SteetDeck ver. 1.0.6.3 on windows XP
    i'm getting an error mesage saying
    "Error in script (main)
    VE Cache-main (161, 1)Error
    -2146827859: ActiveX component cant
    create object:
    'ZipCodeDLL.ZipCodeLookup'
    I aslo tried registering the dll. but had no success. It says,
    LoadLibrary("scriptprojectPath\COM\ZipCodeLookup.d ll") failed - The specified module could not be found.
    What am i doing wrong? thanks in advance.
  4. #104
    Sep 2005
    Quote Originally Posted by marchello2000 View Post
    Marchello
    you are absolutly right. the reason punkerguy is getting the error is that he doesnt have the virtualEarth folder within street deck available. My code assumes that this folder structure exist. I'll rewrite the code to make those checks and create the folders if needed.
    about the offset, when i first wrote it i used 11 but it was one more so i used 10. but its seems to be working for everyone. so thats good. I am actually getting the trailing "\"
    the install screen shot is the hardest for me to capture. the issue is the you need the development env up inorder to choose to package the digimod for distribution. but once the packaging begins, the dev env cannot be minimised so SD takes a screen shot of whatever is on the screen.
    I wonder how others are doing it. but this is a onetime thing so it shouldnt be a big deal if people see the dev environment during installation.
  5. #105
    Sep 2005
    Quote Originally Posted by kiddmaff5646 View Post
    create object:
    scriptprojectPath is suppose to be substituted for the actual path of your streetdeck directory.
    for example mine is
    C:\Users\BM010352\Documents\StreetDeck\Scripts\{FE 67B8EB-7293-4A66-A85F-E3338090B87C}
    so i will replace scriptprojectPath with the above text and run it. but remember it has to be the path in your pc.
    just go to
    My documents\Streetdeck\Scripts\{FE67B8EB-7293-4A66-A85F-E3338090B87C}
    copy that path from your explorer browser and replace "scriptprojectPath" for it.
  6. #106
    Sep 2005
    also its not apparent by looking at the digimod but you can download all the defined zoom levels by moving the zoom slider to the max.
    Has anyone tried this yet?
    Also has anyone downloaded the entire city with all the zoom level? with the max cell? I would like to know how long it took to do so or if there were any timing out issues.
  7. #107
    Jun 2007
    hey bembowe i'm new to this just wondering if u could help me register the dll's im still having a problem. thankxx
  8. #108
    Jun 2007
    Bembowe thank you so much " yay it works!!" downloading maps right now thankxx again!!
  9. #109
    Sep 2005
    do you have vista or xp?
    open up the folder to my documents\Streetdeck. and go to the script folders and select the {FE67B8EB-7293-4A66-A85F-E3338090B87C} folder. take a look at the picture attached. on your browser copy this path.
    if you have xp, do a start->run
    or if you have xp type the following command on start search textbox
    regsvr32 "C:\Users\BM010352\Documents\StreetDeck\Scripts\{F E67B8EB-7293-4A66-A85F-E3338090B87C}\COM\ZipCodeLookup.dll"
    basically all you are trying to do is find the path to where ZipCodeLookup.dll is located and register it. if you want you can move the ZipCodeLookup.dll to c:\ZipCodeLookup.dll
    and register it using the following command
    regsvr32 "C:\ZipCodeLookup.dll"
    let me know if that helps
  10. #110
    Sep 2005
    Great, never mind the last post then, i'll leave it up there incase someone has a similar issue.
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  3. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  4. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  5. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
