Page 5 of 19 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 184
Thread: Virtual Earth cache builder? Or even gps simulator to make it cache?
  1. #41
    Sep 2005
    Quote Originally Posted by marchello2000 View Post
    Download it from: http://www.vulfson.com/SDMapCache.exe
    Mark
    p.s. Thanks for the pointer Chuck!!!
    Hey marchello2000.
    i am trying to download your executable but getting a error when running it. it looks like the file is only 28.8k, seems a bit too small compared to the one i download a couple of days before. Can you look into this.
    thanks
  2. #42
    Sep 2005
    Redmond, WA
    I just downloaded it to a clean computer and it works OK. The executable is only 28k. What error are you getting?
  3. #43
    Sep 2005
    i have attached the error am getting. I believe i might not have the .net framework installed on my home pc. i'll try to install that and see if that resolves the issue
  4. #44
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    That's usually what you get when you don't have .NET installed... FYI
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  5. #45
    Sep 2005
    Yeap, installing .NET resolved the issue. now ama get my download on.
  6. #46
    Apr 2007
    marchello2000,
    Thanks man for making this program up, I am glad you found a little time to do it! I did end up getting my entire city cached, only took about 700mb at all zoom levels. It took many many hours to do because its hard to pan around to get the whole city, even at doing 20 tiles each way at a time. It gets sort of complicated when doing it that way because its hard to know what you have cached and what you haven't. You can try counting over 40 panels to cache an entirely new area, but all that gets really confusing when you have to start panning up and down and left and right and trying to count where your at and all. But hey, beggars can't be choosers right
    Thanks so much for your hard work to help us out. It gets the job done!
    - Mike
  7. #47
    Sep 2005
    hey marchello,
    am still confused about what the cells box mean. I have tried putting 9 and 20 and saw no difference. what is that box for. thanks
    I re-read your orginal post and it does say that .net framework is need. i must have just glimpse past that.
  8. #48
    Apr 2007
    Quote Originally Posted by bembowe View Post
    hey marchello,
    The cells box mean how many squares on each side of the one in current view that the program will download in each direction. So, if you put in 20, then you 20 squares over in each direction, so you end up downloading 20 up, 20 down, 20 left, and 20 right.
    - Mike
  9. #49
    Sep 2005
    Redmond, WA
    That's exactly right. In effect if you specify 5 cells you are downloading 11x11=121 cells. (5 + 1 + 5)^2.
    Ok, so I was thinking. Would this be helpful to you:
    1. You se the zoom such that you see all of the area you care about.
    2. Then say download everything in the current view with zoom from x to y, where x and y are user specified?
    I think this would be a quick and easy way to download a large area. I will also make it multithreaded so that downloads go a little faster..
    Mark
  10. #50
    Dec 2006
    MA, USA
    I like those ideas but I also think that you should have the option to download all the zoom levels between the user defined input (like 5 - 20) within there desired location. I know that may be a lot and I mean A LOT of pictures/hdd space but it still seems possible and probable to me, what do you think?
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  3. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  4. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  5. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
