Results 1 to 10 of 11
Thread: How to set the zindex of the back and home buttons?
    Sep 2006
    Sydney
    I’m new to SD scripting. I’m just trying to make a simple app.
    I have a module that creates an Host window.
    hWndHost = (int)module.CreateHostWindow();
    That is fine however how do I set the zindex of the back and home buttons to be above this window?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    You can', you have to cut regions out of the host window that you don't want to cover up StreetDeck.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Sep 2006
    Sydney
    Is there any sample code for this?
    Is there more than a couple pages on a wiki? Is there an API document?
    Jan 2004
    The call is the windows API call ::SetWindowsRgn. It may be easier for you to just make an overlay that is restricted to your module though and put duplicate Home and back buttons on it. Overlays will automatically be cut out of the embedded window by StreetDeck.
    Sep 2006
    Sydney
    No overlays will go over the module after
    has been called.
    ideas?
    Jan 2004
    Did you follow the instructions in the tutorial?
    http://www.mp3car.com/wiki/index.php...od_%28Addin%29
    If you play a music item, then goto the example digitalmod in the tutorial, does the playing media item show up in the lower left cut out of the embedded window?
    Sep 2006
    Sydney
    Yes I have read that and I did use the example as a base.
    My problem is that after I call
    module = app.CreateModule("StreetDeckDestinatorAddin");
    I have a white window with nothing except the media arrow and track name on the bottom of the screen.
    The overlay I created with
    StreetDeck.Panel btnShowOverlay = (StreetDeck.Panel)module.CreatePanel(StreetDeck.en umCreatePanelType.eCPTButton, "BUTTONOVERLAY.BACK",
    "DestinatorBack", //This is the function name that will be given back to us in any OnExec call and for all intents and purposes is the name of this panel
    app.GetSystemMetric(StreetDeck.enumSystemMetrics.e SMGenericModuleClientX),
    app.GetSystemMetric(StreetDeck.enumSystemMetrics.e SMGenericModuleClientY),
    96, 96);
    Does NOT go over the white background.
    I would just like my overlay (the back button) to stay on top like the media section at the bottom of the page.
    Jan 2004
    Do other system overlays show up though like the media tray overlay?
    Jan 2004
    Quote Originally Posted by Deadeye View Post
    96, 96);
    You are also not creating an overlay there. You are just creating a button. An overlay is on the same level as a module... it contains other panels (controls) in it. To have a button show above your embedded window, you would have to create an overlay, then create a button on it.
    This would look something like this:
    Code:
    StreetDeck.ScriptOverlay overlayRecognition;
    //Create an overlay that will contain the other controls.  Overlays are global and will be shown
    //above every other module
    overlayRecognition = app.CreateOverlay("VoiceShowRecognitionOverlay");
    StreetDeck.Panel btnShowOverlay = (StreetDeck.Panel)overlayRecognition.CreatePanel(StreetDeck.enumCreatePanelType.eCPTButton, "BUTTONOVERLAY.BACK",
                              app.GetSystemMetric(StreetDeck.enumSystemMetrics.eSMGenericModuleClientX),
                              app.GetSystemMetric(StreetDeck.enumSystemMetrics.eSMGenericModuleClientY),
                              96, 96);
    Sep 2006
    Sydney
    YAY
    thanks thats better.
    when do you expect the API doco will be released? evan a beta copy?
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Left arrow key has 'back' function associated with it
    By S4Per in forum StreetDeck Bug Reports
    Last Post: 03-17-2007, 02:06 AM
  3. fabricating dash xenarc 700tsv buttons help
    By michaelrj9 in forum Fabrication
    Last Post: 03-16-2005, 05:34 PM
  4. I'm Back, It feels good to be home
    By Kinnish in forum General MP3Car Discussion
    Last Post: 06-26-2002, 07:00 PM
