Results 1 to 4 of 4
Thread: Dev Issues Maybe Bugs
    Apr 2007
    San Dimas, Cali
    Non of my digitalmods work while moving with module_IsSafe=True. Can anyone else use the digitalmods that are available while moving? I think all of them have that flag set to true. Is this a known bug?
    Code:
    Function Module_IsSafe()
    	module_IsSafe = True
    End Function
    Also, I am trying to preform an action before SD shuts down using Overlay_OnShutdown. I tried this and it doesn't work. Is there a different way to accomplish this?
    Code:
    Function Overlay_OnShutdown()
    	Overlay_OnShutdown = FALSE
    	'Do some stuff
    	Overlay_OnShutdown = TRUE
    End Function
    Another problem I have is that the following does not store the value persistently when I restart SD. I am using it for both a module and an overlay if that matters.
    Code:
    module.SetStringOption 0, ProfileName
    ProfileName = module.GetStringOption(0)
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    What version are you running. 1.1.0.0 fixed a problem with return values being ignored in scripts.
    Is there an options.sdo in your scripts path and does it change when saving? This is where the opitons should be stored.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Apr 2007
    San Dimas, Cali
    Quote Originally Posted by god_of_cpu View Post
    Actually, I think it is just not working in the overlay. I think it's working fine in the module. The options.sdo is there. Did you fix that bug in the overlay also? I don't think there are many examples using overlays, so maybe no one tried yet. Yes, I am running 1.1.0.0 (release version). Do these type of options read and write the hard drive each time or do they get stored in memory?
    I want to release the speed volume digitalmod I made and this is holding me up. I will triple check my code again to see if it is my mistake.
    Please comment on the other items when you have time. Thanks.
    Jan 2004
    Quote Originally Posted by IandI View Post
    Return values are working in 1.1.0.0 for overlays, so is saving of options.
    Does the following code work for you if you implement it. Basically, you should see a message box when the back function happens and the back function should be cancelled since TRUE was returned. The count should be incremented in the message box every time it is called and the count should continue incrementing after restarting StreetDeck from where it left off.
    Code:
    'Overlay_OnFunction
    'DESC: event OnFunction - Called when a function is sent to the panel, return true if the panel processes it
    Function Overlay_OnFunction(eFunction)
    	If  eFunction  = eFUnctionBack Then
    		overlay.MsgBox "Back", overlay.GetIntOption(1)
    		overlay.SetIntOption 1, overlay.GetIntOption(1) + 1
    		Overlay_OnFunction = TRUE
    	ElseIf eFunction = eFunctionStop Then
    		overlay.SetIntOption 1, 0
    	else
    		Overlay_OnFunction = FALSE
    	End If
    End Function
  1. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 07:48 PM
  2. 1.6 Bugs (sorry)
    By GReeToZ in forum Centrafuse
    Last Post: 03-06-2006, 10:08 PM
  3. Replies: 0
    Last Post: 06-14-2005, 10:46 PM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 05:02 PM
