Have already done that, please see My Destinator plugin has been released for details.
Cheers
James
If you're having problems with a specific digital mod I would really recomend posting in that thread and asking that developer to help you.
Jan Bennett
Cheers
James
All I see is
WARNING: CScriptProject::Create - Could not create addin (StreetDeckDestinatorAddin.Main) ERROR=0x80040154!
Can you run again with verbose logging on (add "-verbose" to the exe path)
Thanks for the reply, just so admin dont get to annoyed I have posted my updated log in this thread My Destinator plugin has been released
From now on i will report all troubleshooting from within there.
Cheers
James
did you follow this setup guide:
http://www.us.ssw.com.au/daniel/Home...tor/Setup.aspx
certainly did, destinator works fine when launched by itself, but the install within SD as per above posts is where the problem lies.
Have you had any luck installing this?
I have 100% same issue with Destinator Adding. All my Digital mods working well (4 of them) and only Destinator's one is Stopped. And YES I did follow installation procedure correctly![]()
BMW X5 Carputer Project
Finished: 85%
http://www.mp3car.com/vbulletin/show...lots-pics.html
