Results 11 to 20 of 24
Thread: a basic clock digitalmod
  1. #11
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    what version are you on?
  2. #12
    Aug 2004
    Pearland
    this is what it shows on mine on developer mode.. which is the only way I can run it on my laptop
  3. #13
    May 2007
    Slovenia
    yes in dev its like your picture.
    I am running 1.1.0.0
  4. #14
    Aug 2004
    Pearland
    maybe god_of_cpu can chime in on this..I set the header fields caption to clock.. and it works in dev mode.. but not in regular mode...
    and unless I go install it in my car.. I have no other way of testing it
  5. #15
    May 2007
    Slovenia
    maybe it is just me, because i messed up with my headers We'll see
  6. #16
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by strohj View Post
    you would have to save a gesture for it in settings
    I was out in the car trying to bind a gesture to this digimod and couldn't seem to find a way to do so. I found where you create/bind gestures, but on the list of 300+ I didn't see any of the digital mods. The tutorial video walks through binding a gestire to an external app (Notepad), which required binding a shortcut number to the external application, which wouldn't I couldn't get it to do for any of the four digimods installed. I know rookie question (and yes, i did search the forums for an answer first)
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  7. #17
    Low Bitrate gfmedia's Avatar
    Aug 2007
    Rochester, NY
    Problem with clock
    I just noticed this weekend that the date below the clock is reading Tuesday Oct 23, and noticed that is where the posting is ended, coiencidence? Is there a fix to this bug? I am running 1.1.1, and the date reads fine on home page, but not in this handy little mod.
  8. #18
    Aug 2004
    Pearland
    really? hmm I will see if I can fix it this weekend
  9. #19
    Aug 2007
    Rochester, NY
    Is it just me or can anyone else confirm?
  10. #20
    Constant Bitrate DAE51D's Avatar
    Nov 2006
    Seattle, WA
    Lightbulb
    Here's another suggestion. So it seems my Infill G4 battery is dead or something b/c if I go into hibernate, my clock is all wrong when I start back up (set to the date/time of hibernate coincidentally ;-p )
    So, rather than rip out the G4 and break it apart to try and replace a battery, it would be awesome if you would implement an auto NIST time sync (I know windows clock has that built in, but it only sync's once a week or something and no way to configure that i know of).
    This should be either (or all)...
    • A button I can push to force a NIST update
    • An interval to have this query a NIST server (only if WiFi signal exists)
    • or ideally upon startup of the module (as in, the car is in my garage, with my WiFi connection, so when i turn on the car, your module will detect the WiFi and NIST sync) before I even leave the garage. AKA problem solved.
    http://daevid.com/gfx/tC
    Infill G4. StreetDeck.
    Installed 09/17/07
  1. Yahoo! News Digitalmod
    By IandI in forum DigitalMods (Scripts / API)
    Last Post: 03-01-2008, 02:03 PM
  2. Powering LCD that has a clock
    By sedgett in forum LCD/Display
    Last Post: 03-17-2005, 12:28 PM
  3. Analog Clock possible?
    By mpfjr in forum Road Runner
    Last Post: 03-13-2005, 11:27 AM
  4. Visual Basic Question????
    By chuckctv in forum Software & Software Development
    Last Post: 12-28-2004, 12:25 PM
  5. Basic Stamps???
    By adjones in forum Power Supplies
    Last Post: 08-24-2004, 12:28 AM
