Results 1 to 10 of 14
Thread: HQCT Media Manager BETA (1.1.1.0-02)
    Sep 2005
    Sweden (South)
    Talking HQCT Media Manager BETA (1.1.1.0-02)
    2007-12-21:
    Just download the file and run. No renaming...
    • Download Radio(1.1.1.0_02).sdz and run it.
    • You still need the extra StreetDeck.INI file to place in your streetdeck installation folder (\Program Files\StreetDeck\) otherwise you will have issues the second time you start streetdeck (alignments are wrong -> just static) This is outside of the plugin and nothing I can control. Just do it.
    Screens:
    Main
    Control Overlay (with presets)
    No Preset
    Radio Control
    Audio settings (more to come)
    Mixer settings
    Source Mixing (needs rework)
    2007-12-17:
    Updated so that it works under 1.1.1.0. If anyone wants the old version, let me know..
    • You still need the extra .ini file to place in your streetdeck installation folder.
    • You still need to rename Radio(1.1.1.0-02).zip to .sdz after you have downloaded it.
    So.. It's in a stable version now, but I'm on PutPut to finish functions in the hardware interface.
    Without sounding too cocky, this is THE BEST addin for the HQCT so far. The addins posted prior to this do not stand a chance.. Try it.. You will see..
    This is a BETA release! Please report BUGS...
    (It is quite possible to have the majority of the functions for any radio hardware as long as there is a DLL for common functions, but this version is for the HQCT. Right now, this addin requires HQCT hardware to run!!)
    You can download the plugin here rename it to .sdz and install it.
    Oh, one manual step is needed to get PutPuts DLL on the happy side: Download this zip file an extract the INI file and put it in your streetdeck folder (\Program Files\StreetDeck\) otherwise you will have issues the second time you start streetdeck (alignments are wrong -> just static) This is outside of the plugin and nothing I can control. Just do it.
    Until problems with the Streetdeck API and Getting panels is solved, the addin is UNSKINNABLE!
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    this looks awesome.. I wish I had a HQCT to test this with
    _
    Mar 2004
    Little Elm, Texas
    great work!
    we really appreciate individuals like yourself that go out of your way to help make StreetDeck a great feature rich product.
    btw - will this work with the new HQCT-eA?
    Jan Bennett
    Sep 2005
    Sweden (South)
    Quote Originally Posted by RedGTiVR6 View Post
    There is absolutely no reason why it shouldn't. To avoid all the bickering about interfaces, dll's, frontend vs driver, etc, I have decided to use the HQCT DLL produced by PutPut. This has support for all the HQCT modules including the -eA. There are no problems with adding additional settins pages for that specific module.
    If we could find some way to give PutPut more time (he has almost none) we could get this addin to be even greater.
    Sep 2005
    Sweden (South)
    The links in the first post have been fixed...
    Newbie danholmes06's Avatar
    Dec 2007
    hi aeroanderz sory to be so stupid but wich file do i rename .sdz ?
    Sep 2005
    Sweden (South)
    the Radio071031.zip file
    NOTE!.. This only wokrs with the 1.0.9.8 version. The SDK has been changes with 1.1.1.0 and I'm currently looking into it.
    Also, I've found a bug in the skins when using sliders. Check this for a workaround...
    Good luck! If you cannot get it going, tell me and I'll help you!
    /A
    Sep 2005
    Sweden (South)
    Updated to support the change in 1.1.1.0!
    The skin issue above is fixed. If you haven't read about it, ignore it!
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    Really? This thing actually works with SD? I might pick one up this week.
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Sep 2005
    Sweden (South)
    It REALLY does work with SD. It's running in my car..
    Some SD API issues still, but it does work nicely...
  1. nGhost Media Center Beta
    By tripzero in forum LinuxICE
    Last Post: 03-05-2008, 12:24 AM
  2. nLite Windows Media Edition
    By IntellaWorks in forum WinNT Based
    Last Post: 03-16-2005, 04:26 AM
  3. neocar media center EN version, here it is :)
    By netsuo in forum NeoCar Media Center
    Last Post: 10-04-2004, 01:36 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  5. Windows Media Player 7 Beta
    By DAlba in forum Software & Software Development
    Last Post: 05-05-2000, 08:35 PM
