Icons??? I've only had sirius a couple weeks and thats the only way I've seen it. Theres different colors for different stations. Rock is red, news is blue, sports are green?, and so on.... So I don't know. But if you figure it out, let us know.
When using the -sirius it works like a charm. Far better than the digimod.
Question though. Ever since using the -sirius tag, my channel icons just show up as red squares. Is there a way to get my channel icons back?
When you use the digimod, you see each channel's icon instead of stupid red squares. Serious downgrade!!!
I've never used the digimod and all I get is stupid red squares. I saw the Icons for about a minute today, when I plugged in a firewire drive, but they have since disappeared. But they were pretty cool for a hot minute. Maybe someday they'll come back from never never land.
I noticed that when I was looking to update the Station Images in XM, it might be possilbe to add the sirruis icons in there. I don't know how it calls them but the path for XM is:
Under your Documents: /Streetdeck/UI/StationArt
There is the folder for XM, I would think they would do the same for Sirius stations. Someone could easily test this if they creat a "Sirius" Folder, then use an image in the following format (this is how the XM ones are): PNG 150x150 and name the file as the station number ex 1.PNG, 2.PNG....
Hope that can help someone, I was personally getting miffed at looking at blank stations or station that have changed names and I couldn't see them, minor irritant, but one nonetheless.
