Results 1 to 4 of 4
Thread: Music Synching with M3U/iTunes playlist
    Jan 2006
    Birmingham, AL
    god_of_cpu,
    How feasible would it be to develop a plug in that allowed you to synch with a playlist rather than a directory? I know I have tons of mp3s (read: 150GB+) all organized by iTunes, and if I could make a smart playlist or playlist that I could update regularly and then allow Street Deck to only synch with those files, that would be much easier. It would eliminate having to copy ALL of the data I want or messing with iTunes' organization of the folders.
    What are your thoughts? It would just require simple text parsing for the filename/location and copying the files.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    There are functions for adding and removing files from the media database exposed in the SDK so it should be possible to make an indexer based on something other then an import directory, however, the first version of the SDK won't be very good for multithread operations like indexing.
    The way I would suggest to do it now is since StreetDeck just uses the Windows Media Player database, is if you just write an external application that runs on its own when you start up StreetDeck to access media player and add files on its own, they *should* show up in StreetDeck since they both use the same database. In other words, if you just write an indexer for Windows Media Player 10, it will be an indexer for StreetDeck.
    Files do NOT have to be in the _indexed folder to work in StreetDeck and they will only be moved there if they are indexed by the automatic indexer which only runs on files in the unindexed media path.
    I haven't tested using media player concurrently exactly like this, but I have done other things like it and have a strong feeling it should work just fine.
    I just made another thread explaining how you can automatically run files, such as your indexer, automatically everytime StreetDeck starts:
    http://www.mp3car.com/vbulletin/show...487#post728487
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jan 2006
    Birmingham, AL
    Will the SDK have easy ways to open connections over WiFi, so you can read the playlist over the network, parse, then add to WMP database?
    Jan 2004
    Currently, the only SDK functions are for downloading a file over an established network connection, but the functionality you describe is something that has been thought about and will make it in some day. You can always load a COM object in the VB Script though to do it. Theres probably a WMI object that would let you do things like that pretty easily.
  1. Music Age/Organization
    By Quattro in forum Software & Software Development
    Last Post: 01-24-2006, 07:12 AM
  2. music for your carputer playlist!!!
    By skeurton in forum Off Topic
    Last Post: 11-21-2005, 10:14 PM
  3. Order music is added to playlist
    By djXternal in forum FrodoPlayer
    Last Post: 09-10-2005, 11:04 AM
  4. all music from all drives to one playlist or library
    By glennwoudenberg in forum Road Runner
    Last Post: 04-22-2005, 01:02 AM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
