Results 1 to 9 of 9
Thread: Anyone having problems if they have MApPoint on their machine?
    Newbie dwhite's Avatar
    Jun 2006
    Detroit, MI
    I do a lot of MapPoint development and have it installed on the same machine I am trying to dev on for StreetDeck. The dev environment seems to have a huge problem shutting down. I waited a long time for it to shut down but it never did. So I just went into Task Manager and blew SD away. Then when I restarted the dev environment I get the COM server busy dialogs.
    Check out my company
    Low Bitrate KMorphosis's Avatar
    Aug 2004
    Faw from heyar...
    No problems here. I've got 04 installed and 4.4 here.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    I got mappoint 2006 on there and have no issues, even worked with 2002
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Elsewhere
    None, and I use MapPoint2006.
    How about the Wiki?
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    Quote Originally Posted by dwhite
    The first thing I can think of is since MP uses COM add-in functionality that MP doesn't like to share the COM service. My suggestion, do one or the other but not both, shut down MP when you plan on doin some dev work. Is there a way to close out of MP and keep your front-end loaded? That way you can do your dev on the front-end and still make use of MP when you need it.
    Luck
    Jul 2005
    Edison, NJ
    Similar problem.. when I shut down Street Deck.. Mappoint.exe just won't shut down -- even if I didn't use it. It doesn't hog resources, but it hides in the task manager without an interface. No problems with COM errors.. though I haven't tried using the GPS on this machine.
    Variable Bitrate debugger's Avatar
    Mar 2006
    CA
    Quote Originally Posted by rdunajewski View Post
    checkout:
    dw.exe crash 1.0.5.3
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Also, SD wants Mappoint (whether 2004, 2006 or 2009) to be installed in the Streetdeck/Maps folder and not the default installation directory. The OP seemed to already have Mappoint installed, which would give you that problem. Read more about it over here...
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    Nov 2007
    Quote Originally Posted by JasonMK View Post
    Doesn't matter where it's installed. It'll work in the original mappoint installation directory just fine. That's where mine has always been installed.
  1. Song sort order problems, suddenly
    By 01black_ac in forum Road Runner
    Last Post: 05-21-2006, 04:56 PM
  2. mappoint problems
    By thewr3tched in forum Road Runner
    Last Post: 04-11-2006, 05:42 PM
  3. Problems with USB CD Boot
    By bad-at-this in forum WinNT Based
    Last Post: 03-10-2006, 06:41 AM
  4. BMv2 Mappoint 800 * 480 .Skin Files
    By IntellaWorks in forum RR Skins
    Last Post: 11-14-2005, 04:03 PM
  5. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 02:08 PM
