Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Your Thoughts On This!
    Variable Bitrate debugger's Avatar
    Mar 2006
    CA
    I want to create an application for a windows mobile 5.0 and xp which will make the touchscreen of the handheld to function as a remote contol for SD thats in the car. It can be connected through wifi or bluetooth and will inherit the gesture interface. The whole idea is to be able to manipulate SD while chillin outside of the car or in the back seat...
    Or maybe something like remote desktop, but with SD GUI open while keeping the user logged in the session and displaying the content on both screens. In other words extending the screen to a handheld.
    Your thoughts!?
    cool video
    Variable Bitrate f1vlad's Avatar
    Feb 2006
    Nashua,NH
    How will you achieve screen syncing?
    Idea is really cool, I'd be willing to try it myself, too.
    f1vlad.com/subaru/sparow
    ■■■■■■■■■■■■■■■■■■■■■ 80% progress (sold)
    Nov 2004
    St Louis
    Quote Originally Posted by debugger View Post
    Your thoughts!?
    I already do this via bluetooth and my PPC Phone using Z2 Remote2PC. It's just like VNC but has more options for settings on the PPC. Took me a while to scale the whole screen on the PPC correctly, but once I got it, works like a charm and doesn't care what front end your running.
    Mar 2006
    CA
    Quote Originally Posted by GizmoQ View Post
    Post more info, including every detail. Can you write a tutorial for the members, everyone will appreciate it?
    Mar 2006
    CA
    Quote Originally Posted by f1vlad View Post
    Idea is cool and not hard at all. I like to hang around the car while i have the music on (for example... ) and I get tired of getting into the car everytime I want to change a track.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Cool idea, I think it will be very difficult to remote the StreetDeck UI to a phone since it uses Direct3D. You should be able to create an Overlay script in StreetDeck that can send functions to it and retrieve the current playing media or other info that then talks to your phone via a COM object and recreate a remote control interface on your phone using the retrieved information.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Mar 2006
    CA
    Quote Originally Posted by god_of_cpu View Post
    Wow all this info right to the point...
    I'll start with the phone interface (J2ME for now, mouse control, simple functions --> , <-- , ^ etc)
    Mar 2006
    CA
    DIRECT3D over remote desktop doesn't work.
    It's terribly slow, but I have run programs that use DirectDraw, Direct3D, and even OpenGL acceleration through VNC. Polling can still be used for those
    programs until wrapper can be written for those interfaces. A GDI wrapper would catch 99% of all normal intended uses of VNC, and would be so much
    faster than other approaches.
    DirectX is COM based, which means you would have to register your own COM component with the same GUID. But if you did that, you would be unable to get to the original COM component. You *might* be able to wrap the 4 or 5 normal DLL entry points and do some pass through tricks, but I think it
    will be much harder than doing so with straight DLLs. That's why I don't want to see effort that could be spent getting a working GDI wrapper spent on DirectX stuff. Get the biggest payoff with the least effort whenever possible, right?
    Low Bitrate gosmondson's Avatar
    Jun 2006
    Fresno,CA
    Good idea.. I have a few PPC devices that have either Bt or wifi, i'll see what I can hookup also..
    There is also an app (ill hunt for it today) which makes your PPC show as a secondary display.. Mabey as the SD multimonitor support takes shape, this could be used.. Mabey have an option to set a display as a "remote" and allow for gesture control...
    Mar 2006
    CA
    Quote Originally Posted by gosmondson View Post
    Let me know if you find any software that does that, so it will work on both monitors at the same time that I can use on my 5.5" origami touchscreen running Win XP using wireless connection to EVDO/Wifi route that's also connected to carPC. I also remember that in Windows server 2003 you are aloud to display the remote session on the primary monitor.
    Yeah with remote desktop connection the color depth has to be set to 32bit in order for it to work, which is hackable, but not default option in NT.
    Sometimes changing it to another value gives you undefined behavior and usually causes a failure in the GDI system.
    I would use VNC. RealVNC or TightVNC will work. Which one you use is a matter of preference. RDP is tied into the Windows graphics subsystem and operates at a much lower level. As a result, Direct3D will not work through it. VNC operates at a higher level and just relays what is on the screen as well as keyboard and mouse control.
    So the best option is to use this software that supports depths from 4 to 32 bits:
    Ultravnc.sf.net
    http://www.anyplace-control.com/feat...nitoring.shtml haven't tried yet!
    Also intertesting info:
    http://blogs.msdn.com/oldnewthing/ar...03/508694.aspx
  1. Replies: 1
    Last Post: 07-16-2005, 03:20 PM
  2. Thoughts on skin design guidelines?
    By Arathranar in forum RR Skins
    Last Post: 06-13-2005, 06:54 PM
  3. Thoughts on my idea.
    By Jinx in forum Newbie
    Last Post: 10-06-2004, 09:03 AM
  4. My CarPC Plan...thoughts?
    By TWBarrett in forum Newbie
    Last Post: 10-02-2004, 05:13 PM
  5. Thoughts
    By txglx in forum Newbie
    Last Post: 11-24-2003, 12:29 PM
