Results 1 to 4 of 4
Thread: Can someone make a DIGMOD for my Cingular Comm Manager??
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    I dont know the first thing about making a digmod or scripting. Could someone help me make a digital mod to connect my cingular communications manager. It should be pretty easy since it is really only one button to connect and disconnect.
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Constant Bitrate lanman1's Avatar
    Dec 2004
    SC
    Quote Originally Posted by polo6979 View Post
    Great idea.
    Aug 2006
    Atlanta, GA
    PRETTY PLEASE ! ! ! ! !! ! ! !
    Can someone help me with it?
    2003 E46 BMW
    Constant Bitrate jsdr78's Avatar
    May 2006
    i am not sure what are u trying to do, but if you are trying to get data from a web base source, all you have to do is create a dial-up connection save that connection with the credentials it needs to authenticate, also check the box to automatic connect. in internet property under connection make sure you select always dial your that dial-up connection you create. this way everytime that you are trying to use anything that is not locally on your computer it will connect and disconnected when you finish. it works fine for me for example whe i click on the weather MOD it will connect automatically and download weather information and disconnect when it complete the download automatic. if i click on any of my web base URL music, it will connect and disconnect if i change to local music
  1. How To use your Blackberry as a wireless modem
    By Wiredwrx in forum Wireless Communications
    Last Post: 09-08-2006, 07:19 AM
  2. False floor
    By i3igmind in forum Fabrication
    Last Post: 02-04-2006, 10:28 PM
