Results 1 to 9 of 9
Thread: Traffic Report Module
    Aug 2006
    Post Traffic Report Module
    I will like to have/built a module for the Traffic Report, for some of you this should be basics, but I have no programming skills .
    Compare to the Podcast and the Weather module this should be an easy one, It will also use RSS, and the interface should be very simple. This is where I want to pull the RSS from:
    http://rss.traffic.com/rss.xml?c=jqH...gDw7cZRg4oM%3D
    Is there any documentation on how to use RSS functions in SD?, any Help?
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Theres no RSS functions per say. RSS is just an online accessible XML file.
    The only StreetDeck function you need to use is Utility.DownloadFile to download the online XML file then just load the MS XML parser as a COM object and parse the RSS feed as an XML file. As you mentioned, both of these things are demonstrated in both the podcast and weather DigitalMods.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Aug 2006
    It worked!, after a quick reading about xml and xml Dom, etc, it was not that dificult, right now its working with text only, maybe you can help me with a question.
    How do I extract just part of the text in a specific node?, for example the date and time that the report was created is part of the title, and I only want to diplay the time.
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    Good luck with this.... another GREAT addition to SD!!!
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Jan 2004
    Quote Originally Posted by filatelico View Post
    Use the vbscript string functions, i.e. Mid, Left, Right, and InStr shoudl do it.
    Constant Bitrate jsdr78's Avatar
    May 2006
    Filatelico that is a good idea. once you have completed that MOD would you share.
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by jsdr78 View Post
    I already have that mod
    Aug 2006
    Thanks Chuck, that should do it.......2 more questions:
    1. How do I calculate the distance between 2 coordinates?
    2. Is there a way to send data to the navigation module from a Digital Mod, like a coordinate or address result, and start the navigation to that location, how?.
    So far the mod does 2 things:
    1.Give you a Jam report for specific routes based on traffic.com
    2.Accident report based on GPS location
    Are they any disclaimers or lagalities about sharing mods?, I would like to post it once its done.
    Jul 2006
    Thumbs up
    Quote Originally Posted by tn6478 View Post
    You alread have a traffic mod? Can you share?
    Kris
  1. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  2. Interfacedefinition for Car-PC Module
    By hematec in forum FP FrodoComm
    Last Post: 12-04-2005, 06:46 AM
  3. The point on NMC [VIDEO UPDATE]
    By netsuo in forum NeoCar Media Center
    Last Post: 08-20-2005, 12:44 AM
  4. Replies: 14
    Last Post: 08-09-2005, 02:26 PM
