Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: Sirius Satellite
  1. #31
    Jan 2007
    Quote Originally Posted by polo6979 View Post
    Still get it after the .net 2.0 install... here is a screenshot of the error.
    I am having the same problem. As a programmer, when i see an ActiveX error it usually means that a DLL (or OCX) is not registered. Could this be the problem? Which DLL's should I look for?
    Thanks,
    Scott
  2. #32
    Aug 2006
    Boise, Idaho
    You need to register SiriusCom.Sirius.dll. You can run the script to register it. It's located in the script directory at ..\My Documents\StreetDeck\Scripts\{56228B41-EF0B-469A-BE38-67AC73CF5C4C}\Addins\RunMeFirst.cmd
  3. #33
    MySQL Error
    Oct 2004
    ok, im just messing with the SD demo
    and when i double click the sirius.sdz file
    it fails durning install
    it does show up under digitial mods, and says stopped
    this "digital mod" needs to be reworked, its using OLD OLD OLD
    sirius code
    also, StreetDeck should support it natively
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #34
    Dec 2006
    I am finally ready to get Sirius on my Streetdeck versus the head unit and notice that the SR-ALP1 adaptor is not available from rush2112. Anyone have current experience with the new adaptor and older tuners or must I switch to a new tuner too?
  5. #35
    MySQL Error
    Oct 2004
    the SC-C1 is better the SR-ALP1
    same price for my interface, but smaller/better/cheaper sirius tuner
    and i did the /sirius switch on streetdeck, its native support worked. a little slow but it worked
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #36
    Sep 2006
    what is the /sirius switch? I have searched and don't find anything.
  7. #37
    Aug 2006
    Boise, Idaho
    C:\Program Files\StreetDeck\streetdeck\streetdeck.exe -sirius
    Quote Originally Posted by vitaminR View Post
    To see the whole list of options:
    C:\Program Files\StreetDeck\streetdeck\streetdeck.exe -?
  8. #38
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by nakinney View Post
    Its a beta feature. I haven't tested it myself yet, but it should work. It should allow you to use StreetDeck for sirius instead of XM, when you run with -sirius, just configure the satellite radio settings for your sirius hardware and instead of XM radio and the XM radio ui should work for sirius.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  9. #39
    Newbie Jakiii's Avatar
    Oct 2006
    Los Angeles, CA
    I'm using -sirius with some success. Streetdeck will play the Sirius (ALP-1) but always resets my Line-In volume to Max. Annoying.
  10. #40
    Feb 2005
    Quote Originally Posted by Jakiii View Post
    I'm doing the same with the SC-C1 and unless ive done a clean shutdown/startup (e.g. not a restart and not a hibernate/standby (which generate their own problems)) when it starts the background system noise is amplified like crazy and actual audio coming in is about half the volume it was at before hibernating/standby.
    When I say background system noise I mean that sound you can hear when you crank up your volume to maximum without any music playing. It's not a ground loop in the vehicle, the alternator, power windows, headlights and AC do nothing at all to the sound so I know it's internal to the system.
    Anyway, you would never listen to the computer at that volume because any actual sound would be deafening (this is quiet noise coming through at music levels) but that's whats strange is that the radio is then so quiet. It ONLY does this if I didn't do a clean startup/shutdown. If I play an mp3 while this sound is coming through, it mutes the line-in when it switches over to the mp3 and the sound goes away immediately. When I mute the line-in manually it also goes away, so I don't know what's going with the line-out when the system powers down, but when it comes back up it sounds like its been dropped down to 1% and then had the gain cranked up.
    P4MST-890 775 MicroATX Pentium Dual Core E2140 , 80GB 2.5", OPUS 320W, MS GPS, SB EXTREMEGAMER PCI, 8" LILLIPUT TS, 15" NEC TS, SIRIUS USB PC INTERFACE, STREETDECK, KICKER ZX850.4, KICKER 2500.1, 2xKICKER SS65.2, 2xKICKER 10"COMPVX
  1. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  2. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 05:55 PM
  3. Sirius Satellite solution for PC?
    By Bailey in forum Wireless Communications
    Last Post: 11-23-2004, 06:35 PM
  4. Sirius satellite radio, can we control it with a PC???
    By JonEQuest in forum General Hardware Discussion
    Last Post: 12-20-2003, 01:26 AM
