OK.. I can't get this to install.
SD recognizes the program, then when i click install, it starts, but I get this error:
http://veedubb.com/gallery/albums/mi...rror.sized.jpg
I've run the script, I've tried the switch... Nothing.
Printable View
dont try to install the .sdz package.. just run streetdeck.exe - sirius.. go into setting setup your com ports etc.. and it should work when you click on satelite radio
OK, for those like me that didn't know where to run this command line:
1) Right click on the shortcut and select properties
2) In the "Target" field, add this to the end of the command line:
"C:\Program Files\streetdeck\StreetDeck.exe" -sirius
The " -sirius" goes AFTER the the quotes in the target field.
Thanks to Goce at mp3car for his help on this!
Great support!
Couple questions that hopefully someone can help me with. I have had my carputer running street deck, using Mitch's Sir-Alp1, but not the command line switch. I have the .sdz package. I will go try that. My question is a little deeper, though.
I have been using the back audio line-in input and just doing 2-channel line-out output. But, I just upgraded my amp and want to use the 6-channel output available on my epia M10000. To get the sound in from sirius, I need to use a new input because the 6-channel on the epia changes the line-in port to the rear channel output port. I know there is a front-panel input on the motherboard, but it uses microphone-in instead of line-in. Is that a problem? Can Streetdeck be instructed to use mic-in instead of line-in? If so, how?
When I try to use -sirius in the target line I am receiving an error. I receive a list of all available commands. I am using the target like this:
Any one have an idea as to what I am doing wrong?
