Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: Sirius Satellite
  1. #41
    May 2006
    OK.. I can't get this to install.
    SD recognizes the program, then when i click install, it starts, but I get this error:
    I've run the script, I've tried the switch... Nothing.
  2. #42
    May 2006
    Quote Originally Posted by mitchjs View Post
    ok, im just messing with the SD demo
    and when i double click the sirius.sdz file
    it fails durning install
    it does show up under digitial mods, and says stopped
    this "digital mod" needs to be reworked, its using OLD OLD OLD
    sirius code
    also, StreetDeck should support it natively
    mitch
    This is what happens to me (Screen shot above)
    Sean
  3. #43
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    dont try to install the .sdz package.. just run streetdeck.exe - sirius.. go into setting setup your com ports etc.. and it should work when you click on satelite radio
  4. #44
    May 2006
    Quote Originally Posted by strohj View Post
    Where exactly do I run this command line? I tried changing the shortcut to include " - sirius" and it didn't work....
  5. #45
    May 2006
    OK, for those like me that didn't know where to run this command line:
    1) Right click on the shortcut and select properties
    2) In the "Target" field, add this to the end of the command line:
    "C:\Program Files\streetdeck\StreetDeck.exe" -sirius
    The " -sirius" goes AFTER the the quotes in the target field.
    Thanks to Goce at mp3car for his help on this!
    Great support!
  6. #46
    Dec 2004
    Miami, FL
    Couple questions that hopefully someone can help me with. I have had my carputer running street deck, using Mitch's Sir-Alp1, but not the command line switch. I have the .sdz package. I will go try that. My question is a little deeper, though.
    I have been using the back audio line-in input and just doing 2-channel line-out output. But, I just upgraded my amp and want to use the 6-channel output available on my epia M10000. To get the sound in from sirius, I need to use a new input because the 6-channel on the epia changes the line-in port to the rear channel output port. I know there is a front-panel input on the motherboard, but it uses microphone-in instead of line-in. Is that a problem? Can Streetdeck be instructed to use mic-in instead of line-in? If so, how?
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
  7. #47
    Dec 2006
    Jacksonville, FL
    Getting error when using -sirius
    When I try to use -sirius in the target line I am receiving an error. I receive a list of all available commands. I am using the target like this:
    Any one have an idea as to what I am doing wrong?
  8. #48
    Aug 2004
    Pearland
    Quote Originally Posted by efficinet View Post
    I believe, (and I might be wrong) that the -sirius part should be inside the qoutes
  9. #49
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    No quotes needed, but may not be using a new enough version of SD that had the -sirius command added
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  1. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  2. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 04:55 PM
  3. Sirius Satellite solution for PC?
    By Bailey in forum Wireless Communications
    Last Post: 11-23-2004, 05:35 PM
  4. Sirius satellite radio, can we control it with a PC???
    By JonEQuest in forum General Hardware Discussion
    Last Post: 12-20-2003, 12:26 AM
