Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
Thread: Sirius Satellite
    Aug 2006
    Boise, Idaho
    Sirius Satellite
    My Sirius Satellite DigitalMod.... Please try it out and let me now if there are any problems.
    After installing you may need to register the COM Library. You can do this by going to the install directory, ..\My Documents\StreetDeck\Scripts\{56228B41-EF0B-469A-BE38-67AC73CF5C4C}, and running 'RunMeFirst.cmd'.
    Also, the script by default is setup to search for the com port but it may not work depending on your setup so you'll need to set it manually. In the above directory edit the file 'sirius.vbs' and change the constant, Const MANUALCOMPORT = 0, to the number of the comport your Sirius module is connected to.
    .Net 2.0 Framework required.
    Aug 2006
    Boise, Idaho
    The download link...
    StreetDeck hosted link:
    http://www.streetdeck.com/sdzupload/Sirius.sdz
    Newbie DiscoBayJoe's Avatar
    Dec 2006
    Discovery Bay, CA
    Awsome. I've been holding off on streetdeck until this was available (Sirius is my primary source of in-car Entertainment).
    Did you develop this for the Rush2112 hardware/drivers?
    Aug 2006
    Boise, Idaho
    Quote Originally Posted by DiscoBayJoe View Post
    Awsome. I've been holding off on streetdeck until this was available (Sirius is the primary source of in-car Entertainment).
    Yes I did.
    Aug 2006
    Boise, Idaho
    God_Of_CPU,
    Is there a way to update the CMusicTray overlay (artist, title, and album art) from a vbscript?
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    HOLY CRAP!!... All I have to say is is THANK YOU! ! ! ! !
    I am going to give this a shot when I get home!!
    nakinney....Thank you for taking the time to make this. I am curious, how long did it take you to make this?
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    Aug 2006
    Boise, Idaho
    Quote Originally Posted by polo6979 View Post
    I worked on it off and on in the evenings for about a month.
    Aug 2006
    Atlanta, GA
    I have a couple of questions for you.
    I bought the Sirius radio from the store with the usb interface adapter. Should I be able to just plug the USB into my PC and it will be automaticly recognized in the streetdeck digital mod?
    Do I need to install any other software or drivers?
    I am just curious if someone is using this for the first time... what all they will need to do?
    2003 E46 BMW
    Aug 2006
    Boise, Idaho
    You need to install the driver. Then, if I remeber right, the driver only supports com ports 1 through 9 so you may need to go into the device manager and do some rearranging.
    By default the mod will search for the com port but if it fails you will need to set it manually. To do that you need to edit the sirius.vbs script and at the top is a contant named MANUALCOMPORT. Change this from 0 to whatever the com port is for the Sirius module. Read post #1 for the full details.
    Also, I know you'll need to run the 'RunMeFirst.cmd' file in the directory since I didn't create a folder named addin and stick the siriuscom.dll into it. If I would have then StreetDeck would register it automatically. Just something I need to fix.
    I'm still looking into making this mod more fully integrated into SteetDeck than it currently is so check back.
    Aug 2006
    Atlanta, GA
    Alright... I am doing the install tonight. I will let you know how it goes.
    Anyone else done this?
    2003 E46 BMW
  1. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 08:49 PM
  2. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 04:55 PM
  3. Sirius Satellite solution for PC?
    By Bailey in forum Wireless Communications
    Last Post: 11-23-2004, 05:35 PM
  4. Sirius satellite radio, can we control it with a PC???
    By JonEQuest in forum General Hardware Discussion
    Last Post: 12-20-2003, 12:26 AM
